Oil Pressure,Temp./Drivetrain Loss
Old May 14, 2003 | 06:24 AM
jeffw's Avatar
jeffw
Default Oil Pressure,Temp./Drivetrain Loss
A few questions here:
1.) What oil pressure are you guys getting cold and hot?
2.) Anyone that has installed an oil temp guage: How long till your oil is fully heated after cold start? Is it quicker or slower than the radiator core to reach operating temp?
3.) Does anyone know if our connecting rods/crank shaft have "oil slappers" that scoop and throw oil for cooling purposes? Are these more efficient than oil sprayers? If not more efficient, I wonder if they could be shaved and replaced with sprayers for better efficiency....
Thanks,
Jeff
Old May 14, 2003 | 08:16 AM
j's350z's Avatar
j's350z
I'll let you know about the oil temp in a couple of days, I installed an autometer guage but didn't want to drill into my oil pan so I am in search of T fittings to tap into the oil cooler... Hopefully it will be hooked up soon....
Old May 14, 2003 | 04:30 PM
EnthuZ's Avatar
EnthuZ
SH*T.......
I've been asking about Oil Temp installs for .........a frigging year!
The pan looks simple.....but I haven't removed mine...YET!
It can't cost too much, but the question is.....Where to install the sensor?
Old May 14, 2003 | 05:29 PM
n00dle's Avatar
n00dle
The temp sensor (sending unit) can also be installed in the oil drain plug. Typical sending unit thread pitch is 10mmx1.0 or 1/8"-27NPT. Find out for sure though, because they vary from gauge mfg. Pick up a new drain plug from a parts supply house or from the dealer and use a drillpress for accuracy in drilling straight through. Thread the hole for the sending unit, install the sender on to the plug and it's done.
Old May 15, 2003 | 03:26 AM
j's350z's Avatar
j's350z
That sounds like a good idea too. I'm not sure which way I will go yet but I know it won't be into the pan. A new pan is $80...
Thanks
Old May 15, 2003 | 12:34 PM
n00dle's Avatar
n00dle
Here's a pic of a modified plug that has a temp sender on it and the stock one right next to it. The plug is not from a Z, but you get the idea....
Attached Thumbnails Oil Pressure,Temp./Drivetrain Loss-drainplug.jpg
Old May 15, 2003 | 12:38 PM
eskimo's Avatar
eskimo
I bet someone could make some money if they made those and sold them on here.....
Old May 15, 2003 | 12:45 PM
n00dle's Avatar
n00dle
Here's a pic of the sender next to the plug to give you an idea of how long the sender is...
Attached Thumbnails Oil Pressure,Temp./Drivetrain Loss-drainplug2.jpg
Old May 16, 2003 | 06:20 AM
j's350z's Avatar
j's350z
I don't think it would work on the Z. I had my car on the lift last night when I installed my pulley and our drain plug is really small. I would want a little more than a 1/16th of an inch around the sender. Also, you would have to take it apart everytime you change the oil.....
Old May 16, 2003 | 10:06 AM
n00dle's Avatar
n00dle
That plug there is the smallest and it comes off fine everytime. The sender stays on once it's put on, it doesn't have to come off for an oil change. It's nothing new, there are companies that sell or provide them with their gauges, like Blitz, HKS, Greddy, etc. Then there are those special cases where you need to make your own.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
