Another Vibration post
Old Aug 15, 2007 | 06:40 AM
PumpedVA's Avatar
PumpedVA
Default Another Vibration post
I started getting a small vibration at 3000rpms and higher. Car shifts fine and drives perfect. The other day when I mearged on the interstate I boosted 7lbs/6000rpms though 2nd 3rd and 4th vibration got worse the higher the rpms but after decell it went from a tight vibration to a really loose vibration to were I thought the rear of my car was going to fall out. Droped the rpms down and it stoped. So today I was planing on taking it to a buddy that works at nissan but its all interstate and man thought I was going to get run over because I needed to keep my speed under 70mph to stop the vibration. So looks like a tow truck time.
Anybody have this problem? Cant feel it in the shifter , just feels like the rear of the car. Drive shaft maybe? axle?
Old Aug 15, 2007 | 07:40 AM
Biochem7's Avatar
Biochem7
Regular
Have you balanced your tires recently?
Old Aug 15, 2007 | 08:11 AM
PumpedVA's Avatar
PumpedVA
yep but even so tires wouldnt give you that loose vibration on decell
Old Aug 15, 2007 | 10:36 AM
Beeker's Avatar
Beeker
I could be way off but maybe your missing some lugs or they are loose. Maybe someone tried to steal your wheels and they loosened some lugs. Probably not but you never know.
Old Aug 16, 2007 | 12:55 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
Are you getting vibration when you lift your foot of the gas when you're moving as well???
Old Aug 16, 2007 | 07:16 AM
PumpedVA's Avatar
PumpedVA
moving its a small tight feeling vibration. If I hit redline and let off its a loose vibration and feels like the rear of my car is going to fall out. I can do normal driving around town and have 0 vibration though
Old Oct 22, 2007 | 07:23 PM
ddelain's Avatar
ddelain
Default vibration
Has there been any more info in this problem?
Old Oct 22, 2007 | 08:22 PM
go-fast's Avatar
go-fast
i would check u-joints and the rear,does the car squeak when backing up?noise/vibration on decel can also be wheel bearings,try turning the wheel left or right on decel and see if the vibration changes.
Old Oct 23, 2007 | 03:09 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Toby,what you are descibing is u joint,s that are going bad,either front or rear on the drive shaft.
Old Oct 24, 2007 | 07:34 AM
PumpedVA's Avatar
PumpedVA
funny thing and easy fix. After I tryed everything I got to thinking, I went 2 years without changing my rear camber arms. A few months again I had dave change them and get my camber back to OEM. Well my tires were bald on the inside and half tread on the outside. SO it was making them feather (sp) in the rear. Had the rear re ballanced and BAM 4oz off on the driver side and oveer 3oz on passanger side. SO no more vibration. Just bald tires now LOL
Old Oct 24, 2007 | 02:22 PM
superchargedg
Damn Noobs
Sweet..............nothing expensive.
lapham3
Oct 7, 2022 03:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
Tochigi_236
Sep 27, 2015 03:40 PM
