07 Test Pipes CEL, Non foulers don't work: FIX? (Read)
Old Sep 3, 2007 | 09:41 PM
billybrun's Avatar
billybrun
Mine is an 06, but it's worth a try. You said you checked that the harnesses were secured, right? Well, I did the same when I did mine, and they felt like they snapped in place, but they don't go in all the way. I don't want to insult your intelligence, but you need to push the plug far beyond the first resistance felt.
I looked at the readings using Cipher when I had the light problem, and it sounds like your findings; plugged them correctly, and light gone.
Old Sep 3, 2007 | 10:01 PM
VitViper's Avatar
VitViper
The fronts were never unplugged, and the back's certainly do feel quite tight, they snapped right in. If they weren't plugged in putting the antifoulers on wouldn't of made the CEL take longer to come on and I wouldn't be getting any current through the signal wire on the harness.
Old Sep 4, 2007 | 07:23 AM
Seb-Specialty-Z's Avatar
Seb-Specialty-Z
Originally Posted by VitViper
What's your non-fouler configuration? Any stuffing between them?
No stuffing. One side I am only using one non fouler and the other side (drv) two.
Old Sep 5, 2007 | 08:05 AM
ZLadie2000's Avatar
ZLadie2000
^^ does this seem to fixthe CEL problem?
Old Sep 5, 2007 | 09:17 AM
Gman2004's Avatar
Gman2004
Good luck! I hope it works.
I can see the days in the future if you trip a cel due to emission parts the government will send you a fix a ticket. After getting the ticket you will have to appear in court to prove that the issue has been fixed. It sounds ridiculous, but with GPS systems and ECU's becoming more advanced it is not unbelieable.
Old Sep 5, 2007 | 09:44 AM
stylett9's Avatar
stylett9
my 07Z is being test fitted with high flow cats today from an aftermarket company. Will i get a CEL with highflow cats as well? or just test pipes?
Old Sep 5, 2007 | 10:29 AM
VitViper's Avatar
VitViper
Tried that configuration, popped a CEL before I even hit 67 miles. Obviously it is the rear sensors tossing the code since removing the stuffing and one non fouler on the passenger side tripped it way sooner.
Old Sep 5, 2007 | 07:01 PM
Seb-Specialty-Z
wow! Nothing yet here.....
Old Sep 5, 2007 | 07:24 PM
tomtom's Avatar
tomtom
what about the gain with testpipe on 07?
is the testpipe with or without resonator?
Old Sep 5, 2007 | 07:55 PM
VitViper's Avatar
VitViper
You're one lucky dog for sure... I was curious about the codes so I scanned them... P0420 (didn't get that with the non foulers + padding) and P2A03.
My next step... two non foulers without padding on both sensors. Cleared the codes and went for a drive. I would scan the ecu every 5-7 miles and drive cycle it (turn the car off/on) every so often to get 5-6 drive cycles in. After 15 miles the ECU was already putting up a "pending" (MIL, but no light yet since it's pending): P0420. 25 miles we've got another pending: P2A03.
Ok... got that. Put stuffing back in the non foulers, cleared the codes... Same drive cycle. 33 miles later, no codes (not even pending). Obviously if there was a problem with the front O2 sensors P2A03 would already be pending...
Go figure?
Old Sep 5, 2007 | 07:56 PM
VitViper's Avatar
VitViper
The gains are substantial. Mine are resonated.
Old Sep 6, 2007 | 08:09 AM
singh's Avatar
singh
_______________
Hmmm...interesting, I'm getting the greddy evott exhaust w/ resonated test pipes in a few weeks...I'll keep you all updated.
Old Sep 6, 2007 | 09:23 AM
VitViper's Avatar
VitViper
Popped a CEL around 52 miles on my way to the coast. I'll scan it when I get home, expecting that stupid P2A03 code again.
Old Sep 6, 2007 | 09:51 AM
warmmilk's Avatar
warmmilk
did u buy the o2 sim yet or are u seeing if u can figure it out with non foulers? i was under the impressino that you bought the o2 sim, and just waiting to recieve it in the mail or whatever
Old Sep 6, 2007 | 10:04 AM
VitViper's Avatar
VitViper
I ordered it Monday (shipped Tuesday). I've been playing with the non foulers to see WTF was up before slicing my harness.
Old Sep 6, 2007 | 04:22 PM
VitViper's Avatar
VitViper
Update:
Throwing code P2A00, now we're getting somewhere
I changed positions of the rear O2's last time I was under the car. Bank 2's went to Bank 1, and vice versa. No longer throwing P2A03 (bank 2 sensor 1 circuit), but P2A00 (bank 1 sensor 1 circuit).
Guess someone at the shop that put my TP's on fugged up my sensor? Dropped it or fugged up the harness? Hm...
Old Sep 6, 2007 | 04:50 PM
warmmilk's Avatar
warmmilk
is there anyone besides vitviper and pikespeak350z that have an 07 with test pipes? if so, r u getting cels?
Old Sep 6, 2007 | 04:54 PM
  #38
VitViper's Avatar
VitViper
97supratt is too, he didn't say what codes or if he's using antifoulers.
Old Sep 6, 2007 | 06:31 PM
  #39
Seb-Specialty-Z
No codes yet here.....
Vit....
Yeah it is very possible the sensor is damaged.
Old Sep 6, 2007 | 08:10 PM
  #40
gothchick's Avatar
gothchick
I recently started throwing a p1168 about every 500-600 miles (A/F sensor circuit malfunction, closed loop control, bank 2). It's happened three times so far. With about 5000 miles on my high flow cats. Guess I need to check the wiring harness & connections and/or get some non-foulers. :-(
Fun fun...
