View Poll Results: Bang for the Buck....
EVO350 3.90 gears
60
65.22%
some type of header and cat back
32
34.78%
Voters: 92. You may not vote on this poll
Best Bang for the Buck???
Old Sep 24, 2007 | 10:17 AM
rlwjr1's Avatar
rlwjr1
Default Best Bang for the Buck???
I have some money to spend and I'd like some input on what to buy.
Please keep in mind that I do all my own installation
Some input on why you voted the way you did would be nice. Thanks
Old Sep 24, 2007 | 10:44 AM
singh's Avatar
singh
_______________
Test pipes+exhaust system
Old Sep 24, 2007 | 10:53 AM
RobertH's Avatar
RobertH
3.90? i think u mean 3.9fd or 3.917, i think the central 20 3.9's are a better bang for buck thank 350evo, but if you do your own installations i wouldnt go that route since u install everything bc i hear there is a fine line installing gears right.
Old Sep 24, 2007 | 11:01 AM
Zmazing03's Avatar
Zmazing03
3.90? Isn't the 350Z 3.53 or something? Really worth doing that swap for a fairly small change? Not like you are going to 4.10s or something.
Old Sep 24, 2007 | 11:04 AM
WTX350Z's Avatar
WTX350Z
it really depends on what your wanting....
Old Sep 24, 2007 | 11:15 AM
mikead_99's Avatar
mikead_99
I said the gears since the question is posed as "bang for the buck". You can spend a lot less and feel a lot more changing the fd out.
Old Sep 24, 2007 | 11:57 AM
rlwjr1's Avatar
rlwjr1
Just stop light to stop light.
I think I, like most others that post polls, have already made up our minds, we just want justification.
With that said, I'm already leaning towards gears. I do mainly street driving and I never use my cruise.
I already have a Z tube, Crawford Plenum, and Crawford HFC. I think finishing up the bolt on stuff plus an ECM flash would lay the ground work for maybe a future S/C. BTW I have a G35 Coupe.
I am a professional mechanic so tools, equipment and know how are not a problem. I can do gears and I can do headers.
Old Sep 24, 2007 | 12:04 PM
Flee0588's Avatar
Flee0588
You'll probably be able to notice the 3.9finaldrive more than a full exhaust.
Old Sep 24, 2007 | 12:33 PM
VitViper's Avatar
VitViper
4.083 final > (intake + exhaust + test pipes)
Old Sep 24, 2007 | 12:45 PM
Greedy4nismo's Avatar
Greedy4nismo
i said headers, only cause i don't have experience with changing gears on a car at all, so i wouldn't know
Old Sep 24, 2007 | 12:59 PM
roz350z's Avatar
roz350z
just my .02, ive heard that putting headers on the Z makes it 10x more fun to drive
Old Sep 24, 2007 | 01:02 PM
XIceDragonX's Avatar
XIceDragonX
bang for the buck power wise, the 3.9 gears... bout 10% more power in every useable rpm... if you're big into the sound and rumble and need something loud, than go with the exhaust.
Old Sep 24, 2007 | 02:11 PM
QuadCam's Avatar
QuadCam
a set of steep gears is a killer NA mod for a car like this.
I had a similar experience with a NA Mustang Cobra (4.6 32V). put 4.10s in the rear, and it was awesome.
Old Sep 24, 2007 | 03:57 PM
WTX350Z's Avatar
WTX350Z
Okay good, then I'm glad I chose Gears for your poll. They def. make stoplight to stoplight more "fun" IMO. I'm not familiar enough with the G/Z cars to say what a good combo of gears and F/I is. but I can say that a 3.9 SHOULD be fine. The trick you run into is making sure the gears don't make each gear in the transmission too short. w/ F/I...or make 1st gear just a tire smoke gear. this can be an issue with Mazdaspeed miata's, that's the only reason I bring it up. I'm sure others on this forum could enlighten on how much this applies here. again I'd bet 3.9 would be fine, but no experience w/ it.
Siqcology
Sep 18, 2019 01:45 PM
darkgt
Dec 9, 2015 02:04 PM
foxsmp26
Sep 25, 2015 09:48 AM
zcardave
Texas
Mar 8, 2003 02:55 AM
Kolinar
Jan 16, 2003 02:06 PM
