Well MY V8 is in!!! (LS2)
Old Nov 2, 2007 | 10:40 AM
  #221
gothchick's Avatar
gothchick
supa tyte jdm, yo
Old Nov 2, 2007 | 11:32 AM
  #222
Zilvia's Avatar
Zilvia
Originally Posted by DustinZ33
another pic from sema...hope you don't mind
I just cant get over how perfect that looks.....like straight up OEM looking
that is just so savage
Old Nov 2, 2007 | 12:28 PM
  #223
Resolute's Avatar
Resolute
So true.
I was checking up on GMHighPermormance and they dyno'd a LS2 with just a cam swap and tune= 490 hp. With cam and head swap, well over 500. This was all on an engine dyno, but the results for so little work are damn impressive. And this looks factory. Call me a Z heretic, but I say long live the next gen Scarab!
Will
Old Nov 2, 2007 | 12:37 PM
  #224
Sk8fe's Avatar
Sk8fe
Old Nov 2, 2007 | 12:39 PM
  #225
QuadCam's Avatar
QuadCam
Originally Posted by Sk8fe
Why are all the vinyl letters backwards?
So you can read the decals when the car is sideways in your rearview mirror.
Old Nov 2, 2007 | 12:43 PM
  #226
Resolute's Avatar
Resolute
LOL! Call me a newb, but it that really why the drifting crowd started the whole thing of stickers being backwards? I gotta say that's both clever and funny.
Will
  #227
allenhaynes003z's Avatar
allenhaynes003z
Garbage Stay Jdm
Old Nov 2, 2007 | 01:04 PM
  #228
Oleg's Avatar
Oleg
Is he for real?
Old Nov 2, 2007 | 01:16 PM
  #229
fallenromeo's Avatar
fallenromeo
Love the car Noah. That engine fits so perfectly it looks factory. Can't wait to see more pics.
Old Nov 2, 2007 | 05:56 PM
  #230
NoahzBurnt's Avatar
NoahzBurnt
Originally Posted by allenhaynes003z
I'm a Piece of Garbage and I love *****
edited for accuracy
Old Nov 2, 2007 | 06:35 PM
  #231
Zilvia's Avatar
Zilvia
Will
drifters didnt start...tho it did start in japan land
Old Nov 2, 2007 | 06:41 PM
  #232
Nforce1's Avatar
Nforce1
wow.. people.....are funny
Old Nov 2, 2007 | 08:45 PM
  #233
Sundeviljay's Avatar
Sundeviljay
very cool
Old Nov 4, 2007 | 09:15 AM
  #234
Tackett's Avatar
Tackett
HERE I fixy for you:
Old Nov 4, 2007 | 09:39 AM
  #235
bhk1004's Avatar
bhk1004
so actually well now that I think about it... noah isnt going to have his car for another like 2-3 months? while they are working on the AC and prepping the LSX for the blower? or are you gonna keep it wwith the LS2 while you wait on the LSX?
Old Nov 4, 2007 | 10:02 AM
  #236
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Noah, I got a chance to check your car out at the show. Looks great, congrats and I'm glad they were able to get it all together in time for SEMA
Old Nov 4, 2007 | 12:00 PM
  #237
WA2GOOD's Avatar
WA2GOOD
^^ Hal, I saw your car there too, it looked much better in person.
Old Nov 4, 2007 | 12:25 PM
  #238
Zilvia's Avatar
Zilvia
whats Lsx
i thought that was the tag for a non chevy car with ls motor swap...
I-r-confused
Old Nov 4, 2007 | 01:06 PM
  #239
myG35zx's Avatar
myG35zx
Can a T56 tranny handle 1400hp? Can a Nissan LSD handle that much power/torque? It will be interesting to see.
http://www.chevyhiperformance.com/te...ion/index.html
A Tougher T56
A Good Reason for at Least 650 Rear-Wheel Horsepower
By Dave Engelman
photographer: Dave Engelman
So whatta we got here, some kinda Frankenstein? Nope, but it's a mischievous compilation all the same. A conjoined six-speed transmission created from Viper and LS1 parts may sound strange, but follow along and you'll see why it's just what the good doctor ordered for our monster Biscayne.
The Tremec T56 six-speed, double overdrive transmission was initially designed by Borg-Warner to handle the brute torque of the original Dodge Viper in 1992. A year later, General Motors bought into its virtues, and Ford came along quite a bit later and planted one in the Mustang Cobra. Though there are many external differences among the transmissions, internally they all look unmistakably the same.
Other than making one fit in a strange chassis along with the hydraulic clutch setup, the one drawback to the T56 is its Bonneville-gear overdrive ratios, but there are two schools of thought on this. Dropping 600-800 rpm with a normal overdrive transmission is usually a great improvement, but making a hi-po powerplant lope along at 1,500 rpm, frequently well below where it starts making power, is another matter entirely.
As a result, Sixth gear was all but useless unless you live in Montana or drive the Autobahn on a regular basis. It also takes some serious horsepower to be able to push that steep of a ratio. For the more pragmatic amongst us, >> these same deep ratios yield amazing mileage numbers, even behind highly modified motors. In its strongest incarnation, a stock T56 will routinely absorb 450 lb-ft of torque, a value assigned after a dizzying WOT test that lasts for 24 hours. The two overdriven gears are 0.74 and 0.50:1, respectively. Some of us like 'em, but others figured they were simply stuck with the crazy gearsets.
George Kreppein, vice president of Manufacturing for Rockland Standard Gear (RSG), has used his relationship with the folks at Tremec to manufacture the proper combination of parts to improve upon the situation. Now, 0.80 Fifth and 0.74:1 Sixth gearsets are available, along with a new 25-spline input/30-spline output mainshaft to make it all work.
The new mainshaft features longer splines where the Fifth and Sixth gearset normally resides, allowing for individual Fifth and Sixth gears--the stock setup employs a one-piece Fifth and Sixth gear assembly. There are four main pieces to the Tremec T56: The case, adapter plate, clutch housing, and extension housing--all made from die-cast aluminum. This helps keep the weight down while maintaining superior strength. The fully assembled transmission weighs about 130 pounds. Like all modern manual transmissions, the T56 employs an internal rail-shifter system that protects the linkage and shift rods within the housing. The shifter itself bolts into the extension housing.
The T56 is a robust and reliable transmission for both the street and track right from the factory. It features tapered roller bearings front to back, constant-mesh synchronized gears, needle bearings under the speed gears, and the double-overdrive design allows for closer-ratio gears throughout the range of the transmission (at least until you hit Sixth).
By upgrading the shifter-gear fork inside the transmission during the buildup, RSG addresses the jumping out of gear problem, a nit common to the T56. And paying close attention to internal tolerances as the unit is assembled ensures long transmission life.
Rockland Standard Gear has been building race versions of the T56 for years. RSG builds various drag and road racing transmissions, including one for the company president's weekend ride: a Grand-Am Cup Z06 Corvette. Mike Weinberg's team, Powell Motorsports, has won the Grand-Am Cup in this road racing series four years in a row (1997-2000) and runner-upped in 2001.
RSG has a bunch of its T56 combinations in the real world living behind engines putting out well over 650 hp at the rear wheels. It has built these bulletproof iterations for road- and drag-racing applications, along with normal replacement applications for people who want the improved gear ratios and internal upgrades for their street ride. The privilege can be yours too, for a mere $3,500 (retail).
With the proper tweaks and know-how, it is now possible to custom build a T56 with alternate overdrive ratios for many applications, and fabricators and transmission rebuilders (e.g., Keisler Automotive Engineering, www.keislerauto.com) have been creating all-inclusive kits and custom adapters to fit the T56 into various vehicles for quite some time. This gear change is good for an additional 800 rpm at the end of a straight, so it'll certainly help our torque monster Biscayne to be more driveable.
Old Nov 4, 2007 | 01:26 PM
  #240
Sk8fe's Avatar
Sk8fe
Outstanding!
Thanks
