Well MY V8 is in!!! (LS2)
Brian Hinson is working with the guys from UPREV(on my recommendation) to ensure EVERY function will be retained. When I decided to do the swap retaining the factory gauges and functions was of a top priority. Guys remember that this swap is the first of its kind and the car was finihsed and rushed to its SEMA debut. There is still some trial and error and last minute this that were not completed in order to meet my SEMA deadline. The car will be going back to brian for some last finishing touches. I am assuming that all of our questions will be answered once the car is complete and videos of the car driving will be available then.
I will say this....Hinson Supercars did an AMAZING job....so much so that people had to point out to their friends that this wasn't the stock motor....i am 100% satisfied with their work and cannot wait to see what number we make now that I have a little more time.
Noah, Awesome work on the car man! I got a chance to see it last night and it looks even better in person! You did a great job and everything on it looks clean!
Now for the question! When is the LS2 coming out and the LSX going to be completed and put in?
FYI
100% CNC Machined Cast Iron (280 KPa Tensile)
True Priority Main Oiling
6 Head Bolts per Cylinder
Siamese Cylinder Bores
Standard 4.400" Bore Spacing
Standard Deck Heights (9.700"Tall Deck to Follow)
Increased Deck Thickness
LS7 6-Bolt "Doweled-in-Place" Billet Main Caps
Max 4.500" Stroke (Tall Deck Version Only)
Capable of 364 to 500+cid (Tall Deck for Larger Displacements)
Wet Sump and Dry Sump Capability
Deep Skirted and Dry Sump Capability
Deep Skirted Head Bolt Holes
Orange Powder Coat
Maintains all OEM LS family exterior mounting features
Accepts all Gen III & IV LS Heads, Cranks, Cams, Etc
Includes Unique New Cam Retainer, Rear Cover and Lifter Retainers and OEM
replacement Cam Bearings
Front Motor Plate Mounting Holes Added
Added Material Above Cam Bearings for Additional Strength
Approximate Finished Weight: 225 Lbs. (Standard deck)
Here's what you get/Here's what you can do:
True priority main oiling for standard hydraulic roller lifters / Oil feed holes can be plugged/restricted for mechanical lifters
9.26" semi-finished deck heights (standard deck) /Can be machined safely to 9.22" deck heights (standard deck)
6-bolt LS7 billet main caps with std. 10mm / LS7 fasteners Can be machined for aftermarket premium 11mm fasteners
3.990" bore, ready for honing Maximum / 4.250" bore @.200" minimum wall thickness
6-bolt LSX bolt pattern Standard pattern for naturally aspirated applications
11mm standard bolts / Can be machined for 1/2" aftermarket head studs
8mm exterior/interior bolts Modified 6-bolt pattern (for boosted applications)
All 5 cam bores for standard (small O.D.) bearings P/N 12453169 / Can be machined to accept 60mm roller bearings
Added material around standard .842" lifter bores / Can be machined for larger lifters and/or 1.060" bronze bushings
7th transmission bolt hole added (per Early SBC) / Stud can be installed for applications where sanctioning body requires
Front motor plate mounting holes added / For racing chassis applications (sprint car, drag racing, truck pulling, etc)
O-ringed screw-in soft plugs / For external heater or coolers
Accommodates any LS small block oil pan or oil pump / Standard LS wet sump systems, and LS7 dry sump systems fit
External oil pump feed @ rear of block / Front oil feed lines can be plugged and external oil pump/aftermarket dry sump systems can be used./ Belt cam drive can be accommodated Main web bay to bay breathing holes for increased HP Access windows for cylinder head stud access (intake side)
Extra breathing pocket added near starter for better windage
edit..found this in the fine print!
HOLY MOTHER OF GOD!
Dream bigger. Because the new GM Performance Parts LSX takes the LS-series V8 to the ultimate extreme. Shaped from 50-plus years of V8 know-how and refined with the speed secrets of Warren "The Professor" Johnson, the LSX block was engineered to handle up to 2,500 horsepower, all for a price that will have the rest of the world wondering how we did it. Build your dream with LSX, available March 2007.
Orange Powder Coat
HOLY MOTHER OF GOD!
I bought the LS2 as well....hence why I am stuck with what to do financially now. I Can twin turbo the LS2 for a good 6XX RWHP and be happy or build the N/A LSX for roughly 6XX rwhp as well...I am completely wiped out so i guess I just need to start saving again.
it is a problem....I am way over budget and really just want to drive the car...either option will get her back to me just in time for the snow....maybe i'll buy a blown up FD RX-7 and drop the LS2 in there to drive around while i build the LSX....i don't know at this point...i am going to go with Brian Hinson's suggestions as to what to do....he knows his stuff and has yet to misguide me (hell he has an 8 second TT LS1 RX-7)
"Originally Posted by GQ 350z
I asked this before but no answer: Would this be a "legal" modification in California? "
Out of curiousity...Why not? Can you not build a street rod in California?
Originally Posted by Wired 24/7
Something has to be done about those valve covers. GTO? Come on!!
Would you change your name after a heart transplant?
http://dev.pfyc.com/mm5/merchant.mvc...ory_Code=C6NEW
http://www.pfyc.com/pc/C63011/C6UNDE...il+Covers.html
http://www.pfyc.com/pc/C63013/C6UNDE...ve+Covers.html
Originally Posted by tahoe-man
As is I'm sure your Z rocks!
