5at shift shock
Old Nov 1, 2007 | 04:59 PM
Silver Fox's Avatar
Silver Fox
Default 5at shift shock
Does anyone else experience a shock in the 5at when shifting from neutral to drive. The shock is more noticeable when the transmission is hot. Engagement is smooth when transmission is cold.
Old Nov 2, 2007 | 08:20 AM
Rollin's Avatar
Rollin
i dont notice a shock, it does engage smooth unless your foot is on the brake enough to engage but wants to leap, especially when its cold and revving higher
Old Nov 2, 2007 | 12:59 PM
SoCalTed's Avatar
SoCalTed
I find a lot of people don't fully wait for the car to stop moving backwards when shifting into drive, or rolling out of a driveway. Then their trannys start acting up. Many people also tend to shift, then release the e-brake when on an incline. Stuff adds up on the wear and tear.
I only experience shift shock when it's cold. (30k on my original tranny)
Are you holding the brake for a second or two after shifting N to D? Try that.
Old Nov 3, 2007 | 01:24 PM
Silver Fox's Avatar
Silver Fox
Nissan service had a look and are still trying to understand the problem. They said that the valve body may need to be replaced - only 8600 miles and not abused.
Old Nov 22, 2007 | 06:23 AM
lowtempo's Avatar
lowtempo
Smile
Change your differential fluid. it cost $38 at any oil changing place. The diff fluild is what lubricates the axel and the driveshaft. I was noticing the same problem as you, along with slow/ slugish shifting. I just changed mine after 80k miles ( i never changed it). Now it excelerates and shift "smooth as butter"....... best $38 i have spent on the Z in a long time.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Suffolk350z
Sep 13, 2015 02:43 PM
