Change Diff gears on 5AT? possible?
Old Nov 2, 2007 | 08:23 AM
Rollin's Avatar
Rollin
Default Change Diff gears on 5AT? possible?
I wnat to do the gears on my 03 AT but doesnt seem like it can be done for whatever reason, does the tranny play that big a part in the ratio not to allow you to do this? Does anyone know, and if so point me in the right direction.. thanks
Old Nov 2, 2007 | 05:14 PM
superchargedg's Avatar
superchargedg
Damn Noobs
A little search would have givin you all the answer,s you would need as it is done all the time.Juat find a pumpkin out of a 6spd manual and all you have to do is bolt it up.......... i think all 03-04.5s are the same.
Old Nov 2, 2007 | 06:00 PM
z2g's Avatar
z2g
^^Agreed
Old Nov 2, 2007 | 06:02 PM
stereoneeds's Avatar
stereoneeds
+1 i did it. just find someone with a turbo who wants your pumpkin and swap.
Old Nov 3, 2007 | 08:42 PM
JOEGYVER's Avatar
JOEGYVER
It's been quite a while since I read that hug thread about the guy who first did an LSD and gear swap in his 5AT, but I believe the stated issue was the ring gear is thicker on the auto model. Can anyone point me to pics about the problem? Is this a common problem in other cars when doing gear swaps, I've never done it? Yeah I know, just swap or buy a 6 speed pumpkin, but I want to see if there are no other options, this can't be the only car that has this issue, and if it is due to oem being too thick, a spacer can't be made or etc.? You can rag on me if you want, but if your "in the know", please share, even if it is not related to the Z
lapham3
Oct 7, 2022 03:15 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
