problems on crank pulley?
Old Nov 8, 2007 | 01:24 AM
j_z2006's Avatar
j_z2006
Default problems on crank pulley?
anyone has problems on ur crank pulley underdrive?
Old Nov 8, 2007 | 02:24 AM
teh215's Avatar
teh215
yes
Old Nov 8, 2007 | 11:39 AM
j_z2006's Avatar
j_z2006
what kind of problems?
Motormouth's Avatar
Motormouth
squeal
Old Nov 8, 2007 | 12:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
ask a specific question you will get a specific answer....
Old Nov 8, 2007 | 12:51 PM
jonnylaw's Avatar
jonnylaw
I wonder if the squeel is due to the belt and not the pulley itself. The stock belts have this fuzzy stuff on the one side and me thinks this helps quiet squeel. I don't believe the Gates belt has this layer and usually get squeely after 10k miles.
I wonder if those with the stock size ur pulley and stock belt also get squeel.
What kind of other problems other than squeel? Has anyone actually had their crank pulley detach itself and cause engien damage, or are the problems solely with nvh and squeels?
Old Nov 8, 2007 | 12:53 PM
Z1 Performance
Former Sponsor
the squeal is due to the belts not being tightend properly - nothing more, nothing less
Old Nov 8, 2007 | 12:55 PM
Nexx's Avatar
Nexx
i dunno, ive had mine tightened so tight there was zero give and they still squealed for the first 5 minutes of driving.
Old Nov 8, 2007 | 12:57 PM
Motormouth's Avatar
Motormouth
I could've sworn is was related to the seal rubbing on the pulley neck... but I wouldn't know better than Adam.
Old Nov 8, 2007 | 01:14 PM
Z1 Performance
Former Sponsor
I've never had any issue using Gates and Goodyear belts - sometimes you get belts that have been sitting around for awhile and get a bit too 'dry', but so long as the belts are fresh and tightened to spec, you won't have any issues. I know it can be an annoying problem- Kwame bugged the **** out of me for a few days because he couldn't get rid of the squeak once, but once he finally listed to me ( ) he was all good. I find that you'll typically get about 20k-30k out of a set of belts, then its time for new ones
Old Nov 8, 2007 | 06:01 PM
j_z2006's Avatar
j_z2006
does anyone know what are the stuffs should be in a UR underdriven crank pulley? 2 belts and pulley, anything else?
Old Nov 8, 2007 | 06:13 PM
Motormouth's Avatar
Motormouth
a turbo kit. and I think a tshirt.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
