Project 2JZ in a 350Z
Old Nov 9, 2007 | 05:20 PM
  #61
Martin XAT's Avatar
Martin XAT
Interesting responses. Thank you all for the insight so far. The original intent still stands and I am just gauging interest. I am in the process of setting myself up at vendor status and as soon as I get the ok I will post the numbers we went over today.
Martin S.
Old Nov 9, 2007 | 05:54 PM
  #62
craigo'sznprgrs's Avatar
craigo'sznprgrs
Martin S.
PM with preliminary findings, if you want to, lol.
Old Nov 9, 2007 | 08:30 PM
  #63
RA11325's Avatar
RA11325
Keep it up Martin! Would be nice to see XAT on the radar on these boards!
Old Nov 9, 2007 | 08:40 PM
  #64
cturnbull802's Avatar
cturnbull802
for the money i might as well get rid of my g and get a cts-v
Old Nov 9, 2007 | 08:49 PM
  #65
Quamen's Avatar
Quamen
Lol.
Considering the amount of money that goes into modifying the Z in any way involving boost or making over 300whp (minus nitrous) that is kind of a funny statement.
Old Nov 30, 2007 | 02:51 AM
  #66
mikespeed95's Avatar
mikespeed95
+1
You guys do fabulous work, and love what you do.
Now just put a LSx swap together, that ACUTALLY HAS AIR CONDITOINING, AND WORKING GUAGES and you'll be set. Because I'm 99.9% sure thats not available yet.
Old Nov 30, 2007 | 08:15 AM
  #67
cturnbull802
Originally Posted by Quamen
Lol.
its not funny, its true!!
Old Nov 30, 2007 | 09:00 AM
  #68
Zilvia's Avatar
Zilvia
Originally Posted by mikespeed95
+1
in what car........
Old Nov 30, 2007 | 09:20 AM
  #69
Lawy'dU's Avatar
Lawy'dU
Originally Posted by G35asian
Ok, so lets compare the cost involved with a built tt vq35 and single turbo 2jz swap:
Built TT VQ35
- Fully built VQ35 ($8-$10k)
- Clutch & flywheel to hold 600rwhp ($1.5-$2k)
- TT kit ($6-$8k)
- Engine management, gauges, etc. ($2-$4k)
- Labor for Everything ($5-$6k)
- Tuning ($500-$1k)
- Miscellaneous ($1-$2k)
Total: right around $25k on the low end of the scale
Stock block 2jz swap w/upgraded single turbo kit
- 2jz motor and tranny with 30-40k miles in good shape ($5-$6k)
- Clutch and flywheel ($1-$2k)
- Custom motor mounts/driveshaft/wiring ($3k-$4k)
- Engine managment, gauges, etc. ($2-$4k)
- Single turbo kit ($4k-$5k)
- Labor for everything ($4-$5k)
- Tuning ($500-$1k)
Total: around $20k on the low side
I'm sure that I left a few things out, but you get the idea. Both will yield you right around 600-700rwhp easily. If you take it up a notch on the 2jz though, they are proven to hole over 900rwhp on a stock block . With a built 2jz you can have a 1000rwhp 350z for a lot less money then with a VQ.
I like both motors and personally don't have money for either (lol), just wanted to add my 2 cents....
this is also considering a non built 2jz lol. a built VQ is not comparable to a stock 2jz
Old Nov 30, 2007 | 09:34 AM
  #70
Zilvia's Avatar
Zilvia
dpftl...
Old Nov 30, 2007 | 11:22 AM
  #71
Skorch's Avatar
Skorch
Considering that a stock block 2JZ can handle up to 900 whp or so, building the 2JZ block for the 500-600 whp wouldn't be necessary. The VQ block would have to be built though to handle that kind of power.
Old Nov 30, 2007 | 02:11 PM
  #72
Zridder19's Avatar
Zridder19
Do you know anything about a 2j?
800whp all day stock block, some doing close to 1000whp.
Old Nov 30, 2007 | 08:47 PM
  #73
rkd350z's Avatar
rkd350z
wow... cool...
Old Nov 30, 2007 | 11:14 PM
  #74
cturnbull802
i just want 450-500 in my g.... but to be reliable it takes 2 much
Old Dec 3, 2007 | 06:37 AM
  #75
warmmilk's Avatar
warmmilk
450-500 is a walk in the park for an internally stock 2jz, u can even hit 450 (i think 490 is the record, but don't quote me on it) on the stock turbos
and the guy saying a stock block 2jz isn't comparable to a built vq doesn't know what his talking about. a stock 2jz is more reliable at 700 whp than a built vq
Old Dec 3, 2007 | 06:45 AM
  #76
cturnbull802
/\ i dont want to spend 10 grand for 450-500 hp
Old Dec 3, 2007 | 07:05 AM
  #77
warmmilk's Avatar
warmmilk
i'm not saying u should, or justifying the price or anything, more just clearing up misconseptions about the 2jz
personally, i'd do an ls1 swap before a 2jz, actually, i wouldn't even do the 2jz swap into this car cause of how much heavier it is than the vq, especially when the turbo and manifold comes into play mounted at the top of the engine and all
Old Dec 8, 2007 | 07:24 PM
  #78
Martin XAT's Avatar
Martin XAT
update on front page
Old Dec 8, 2007 | 08:40 PM
  #79
cturnbull802
my only question is if my rwd 6 speed will bolt to the VR38TT
oem reliability 500-600whp with what? a boost controller?
Old Dec 8, 2007 | 09:22 PM
  #80
Quamen's Avatar
Quamen
Can you explain the fuel pump setup in the picture?
