Chatter Chatter
Old Nov 15, 2007 | 12:50 AM
hard_charger's Avatar
hard_charger
Default Chatter Chatter
I spent a lot of time searching the threads but didn't find anything that quite addressed a noise I've been hearing in my 350Z.
I've noticed that when clutching in at low, low speeds (when pulling into my tight parking space at home and when parking at work) there is occasionally a ton of noise. It's a metallic chatter-like sound.
For comparison's sake, it sounds like the noise you get when you're just catching the clutch to keep the car from stalling. Only difference is that I'm no where near stalling the car when I hit the clutch and the noise occurs. It doesn't happen every time.
I get a similar metallic noise from time to time when cruising over the speed humps in my complex at 10-12 mph.
Any ideas about what is going on or if I'm doing something wrong? The car is a 2007 Enthusiast and has about 1,300 miles on the clock. Thanks.
Old Nov 15, 2007 | 01:15 AM
SuperBlack350z's Avatar
SuperBlack350z
It's quite normal. If you do a search, you'll find threads on it.
Old Nov 15, 2007 | 01:19 AM
hard_charger
I guess my searching skills need work. But I promise I spend upwards of an hour scoping out the threads. Thanks.
Old Nov 15, 2007 | 04:22 AM
Wolffe G Puppy's Avatar
Wolffe G Puppy
Is it a metal-to-metal type sound? I get that sound anytime I`m in 2nd and 4th gear (input shaft bearing?). Seems like Z32 and Z33 manual trannies make that same sound. What exactly would cause input shaft bearing noise and what would be the cure? Surely bearing noise isn`t a good thing,right?
Old Nov 15, 2007 | 07:38 AM
Kieran@DrivenDynamics's Avatar
My car never made this noise till after I took it in for service. I'm not convinced it's normal, it does it while sitting idle now.
Old Nov 15, 2007 | 07:41 AM
SuperBlack350z
Go test drive a brand new z. it will make that sound.
Old Nov 15, 2007 | 10:02 AM
bbs350z's Avatar
bbs350z
is called cluch chatter. when you upgrade to a lighter flywheel, the sound will amplify as well
Old Nov 15, 2007 | 10:08 AM
reptile718's Avatar
reptile718
+1 I have the JWT flywheel and it gets pretty bad sometimes.
Old Nov 15, 2007 | 10:55 AM
OliverH22's Avatar
OliverH22
Check these vids on this thread out:
https://my350z.com/forum/engine-and-drivetrain/314513-clutch-tranny-noises-2007-350z-enthusiast-w-vids.html
Are these the sounds you are hearing? (specially on the 4th vid)
Old Nov 15, 2007 | 05:00 PM
cheshirecat79's Avatar
cheshirecat79
Normal.
Old Nov 15, 2007 | 10:32 PM
Justin350z03's Avatar
Justin350z03
yeah man. Mine does it all the time. Quite normal. It's a pain to listen to sometimes at idle
Old Nov 16, 2007 | 06:13 AM
OliverH22's Avatar
OliverH22
BAN plz?
iron1mike_alpha
Sep 19, 2011 10:37 AM
Alang35
May 19, 2006 06:31 PM
JKDman
Jun 16, 2005 11:51 PM
bknezevic
Apr 7, 2005 05:53 AM
LouieIV
Cleaning & Detailing
13
Apr 29, 2004 09:23 AM
