SPEC clutch...
Old Nov 18, 2007 | 07:35 PM
TheBlackPearlZ's Avatar
TheBlackPearlZ
Default SPEC clutch...
whats the gernal consensus on this kit...im looking at hitting 500 hp with the set up ive recently started building, and i want to make sure this kit is good for the job.
twin kit, SS trim...??
any thoughts
Old Nov 19, 2007 | 04:00 AM
Quamen's Avatar
Quamen
any thoughts
I'll be honest and say that I don't know how they are for the Z but I do know that David Norton is a great guy to deal with and his work is top notch. We use custom made spec clutch and flywheel setup in our Porsche 928 race car an it has held up for 2 years of hard track abuse.
Personally, I would shoot David an email at specsales@specclutch.com and David will most likely get back to you within a day. If you tell him what you are looking for feel and power wise he won't mislead you into getting the most expensive thing but will rather help you get the clutch setup that will suit your needs and desires.
In regards to feel and my experience I think they feel great on the 928. Our clutch is for high torque so it is either on or it is off and we also have a 10lb spec flywheel so it can be tricky to start off. Remember this is an extreme setup compared to what you will most likely get and I still think that the 928 is drivable whenever I have driven it.
Good luck and feel free to PM me with any questions you have.
Old Nov 19, 2007 | 06:40 AM
Zivman's Avatar
Zivman
any thoughts
I've had spec clutches and while I liked the feel, I ate up two of them. I would recommend an ATS or Exedy JDM spec over the spec
Old Nov 19, 2007 | 06:44 AM
Zivman's Avatar
Zivman
any thoughts
Good question for you... why are you going with the extreme kit if your goal is only 500hp? you can make 600hp on the base kit without much issue at all
Old Nov 19, 2007 | 06:54 AM
Quamen's Avatar
Quamen
Can you add some additional info such as what level clutch you had, what power level you were at, where you launching hard and what type of abuse the car was getting?
Old Nov 19, 2007 | 07:05 AM
Zivman's Avatar
Zivman
I ran a spec 2+(I think it was rated at 525tq) at around 450 and the pressure plate went out within 3K miles. Replaced under warranty. Attempted to get retuned for something around 500 and the clutch would just slip. I called spec directly and asked them about a clutch they offfered that would hold my power. I advised them I would be looking for 500-550 hp and comparable tq. They told me I would need at least a 3+, prefferably a stage 4 or 5 plate and would need that paired with their stage 5 pressure plate. No thank you. Went with an ATS twin disc and couldn't be happier.
edit, car was just street driven. No hard launches as traction is not even an option in 1st -3rd. Did a few highway pulls in 4th, but never really beat on it. Keep in mind, both spec clutches were properly broken in prior to even doing any aggressive driving
Old Nov 19, 2007 | 07:16 AM
TheBlackPearlZ
im getting ready to get a triple disc...whats is your power lvls at right now...im going to be looking at 600+ and want something to handle it
if i can get there with just a twin disc ill go that route...what do you think??
Old Nov 19, 2007 | 07:35 AM
Zivman's Avatar
Zivman
Get the triple
I am at 550
Old Nov 19, 2007 | 07:43 AM
TheBlackPearlZ
ok good deal...triple it is then =]
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
