Transmission Warranty Question
Old Nov 22, 2007 | 09:15 AM
Chaser720's Avatar
Chaser720
Lemoned Z
Default Transmission Warranty Question
Sorry if this is the wrong place for this post but yeah...
Im currently on my second tranny on my 06 Z and its currently have the same problem as the orginal one (grinding into 6th gear while engine is reved over 3K). The first was replaced under warranty but i had the stock clutch. I upgraded to a JWT clutch and flywheel and ive heard that this voids the trannys warranty.
Any help on this topic would be appreciated.
Thanks
Old Nov 22, 2007 | 02:41 PM
cheshirecat79's Avatar
cheshirecat79
Thanks
Was the clutch and flywheel upgraded by the nissan techs when you had the first tranny replaced?
You can always just go to a dealership and tell them straight up what's going on and get their take on it.
Old Nov 22, 2007 | 03:31 PM
Chaser720's Avatar
Chaser720
Lemoned Z
It was replaced by a respectable aftermarket performance shop and talking to nissan is what i was planning on doing. Thanks
Old Nov 22, 2007 | 04:22 PM
Did the clutch and flywheel cause the transmission problems?
Old Nov 22, 2007 | 08:58 PM
toy4two's Avatar
toy4two
I would not take the chance, Nissan would have a good case since you didn't use OEM parts, who's to say the non-OEM parts were as balanced as is needed in the Nissan tranny (stupid I know) but I would swap in OEM stuff before talking to them about warranty work on it. If it was an air filter or exhaust, hell yea, but when you start changing internal parts things get complicated.
Old Nov 23, 2007 | 09:02 AM
Chaser720's Avatar
Chaser720
Lemoned Z
With the stock stuff i still had the same problem so im going to try and argue with that. Can they tell that its an aftermarket clutch by just looking at because i remeber them looking pretty similar.
Old Nov 23, 2007 | 09:32 AM
HondaKiller's Avatar
HondaKiller
it probably wont jump out at them untill they look at the flywheel.
Old Nov 25, 2007 | 06:18 PM
Chaser720's Avatar
Chaser720
Lemoned Z
Alright then. Im just going to play stupid until they find something.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
