Visual difference between Rev-Up and non Rev-Up
Old Dec 3, 2007 | 05:19 PM
QuadCam's Avatar
QuadCam
all 6MT revup G35s have VLSDs. it is part of the sports package.
Old Dec 3, 2007 | 06:16 PM
KPierson's Avatar
KPierson
Thanks, I'm so 'out of the loop'!
Old Dec 11, 2007 | 04:47 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Originally Posted by QuadCam
OP....you are correct. The revup has different cam timing gear covers. the cover looks like it is hiding 2 circles as opposed to 1. here's a pic of the front timing cover of a revup.
Sorry, I've gotta ask. What the hell does OP stand for? I can't figure it out.
<<<Post jack complete>>>
Old Dec 11, 2007 | 06:01 PM
KPierson's Avatar
KPierson
In this case, OP is me!
OP = Original Poster - the person who originates the thread.
Old Dec 12, 2007 | 10:26 AM
gothchick's Avatar
gothchick
A non revup looks like this.
Attached Thumbnails Visual difference between Rev-Up and non Rev-Up-picture014nc1-1-.jpg
Old Dec 12, 2007 | 12:18 PM
QuadCam's Avatar
QuadCam
nah....You're the OG....Original Gangsta!
Old Dec 14, 2007 | 09:17 AM
ART_'s Avatar
ART_
Originally Posted by The_VQ
Oh, and both non revup VQ35DE and revup VQ35DE have 4 cams, those are DOHC engines.
Old Jan 22, 2008 | 05:51 PM
supra crazy's Avatar
supra crazy
Would a Revup motor work correctly with a non-revup harness and ECU? until i get the money to get a rev up hanress and ECU? stock motor failed and got a Rev-up. please help need my car running asap. PS has Greddy TT kit and Emanage Ultimate.
Old Jan 23, 2008 | 02:16 AM
KPierson's Avatar
KPierson
I personally think it would run.
I have a rev up harness and ECU for sale, PM me for details.
Old Jan 23, 2008 | 05:41 AM
gothchick's Avatar
gothchick
Yeah - You'll need to swap the ecu and harness if you go from a non revup to a revup. From what iv'e heard, it's not worth it cause it's a total PITA. And the gains of a revup over a non revup are minimal if any.
Old Jan 23, 2008 | 07:46 AM
KPierson's Avatar
KPierson
I think it would be required to swap the ECU and wiring to get the exhaust and intake vvt to work, but the motor will still run without the full vvt hooked up. You obviously won't see any power increase without everything hooked up, but for a person in your situation it should work.
As far as I know the crank trigger is the same, and the cam triggers are the same. As long as they haven't changed electronically everything should work on the old ECU. However, if the signal plate on the newer crank is a different pulse per revolution then you will have issues. One easy way to verify this is to check compatibility of 03/04 flywheels with the Rev-up flywheels. If they are identical then you can rest assured the signal plate is identical.
Old Jan 23, 2008 | 12:01 PM
rkd350z's Avatar
rkd350z
red line got 1/4inch longer
and you can see that nissan just colored the redline to black.. untill 7000rpm
Old Jan 23, 2008 | 10:42 PM
mavtais's Avatar
mavtais
I wonder if someone has switched the heads on the non-revup to a revup. If it is the bottom end of the revup that causes the oil consumption, you could take the more solid non-revup bottom and get a better intake (like any of the plenum choices). Could you make more power or the same as a revup but not have to worry about oil consumption? I'm interested in getting "electromagnetic lift" on the exhaust cam for more high rpm power. I want to consider this as an alternative to just getting a set of cams that are always mean.
350z82
Oct 1, 2015 06:25 PM
