Oil starvation under hard braking
Old Dec 31, 2007 | 06:14 AM
lama's Avatar
lama
Default Oil starvation under hard braking
I just noticed that when braking hard and cornering, the oil pressure gauge would basically drop to zero, and the oil light would come on (the car even shut off once). Oil pressure at idle and above is within the service manual limits. I checked the oil level and its at the high line and there is no oil leaking on the ground. Major engine mods is a Greddy TT. I'm not sure if there is a oil spacer or not. If so would a oil spacer help?
Old Dec 31, 2007 | 06:51 AM
sentry65's Avatar
sentry65
the burninator
does anyone by chance know where the oil pressure sensor itself is actually located?
Old Dec 31, 2007 | 07:05 AM
lama's Avatar
lama
bottom corner next the oil filter with a harness attached to it.
Old Dec 31, 2007 | 08:49 AM
gothchick's Avatar
gothchick
A baffled aftermarket oil pan will fix the issue... (APS, ARC, Power Enterprise, Greddy, Etc...)
Old Dec 31, 2007 | 08:54 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
+1
Old Dec 31, 2007 | 06:26 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Before spending money, check your oil level, lots of these cars use oil between oil changes, you may be low.
Chris
Old Dec 31, 2007 | 07:29 PM
mthreat's Avatar
mthreat
Hmmm this is concerning. I brake very hard at the track (it's where I catch up to those fast Porsche's!), I'll have to keep an eye on the guage next time, without flying off the track in the process. I've noticed the guage seems to lag a little bit. I've watched it through some long, hard sweeper turns before. I've seen the pressure drop, but not all the way to zero, and definitely no oil lights came on.
Old Jan 1, 2008 | 03:34 AM
lama's Avatar
lama
Chris
Hey thanks, well i checked it again and low and behold it was low. The first time i checked it i only had a minimag and i've only had the car for 2 weeks so i wasnt aware of how crappy the dipstick really was. Now with some real lighting what i thought was full was just all the residual oil and not the actual oil level i originally thought it was. Thanks again!
Old Jan 1, 2008 | 03:41 AM
lama's Avatar
lama
Yes, i was very concerned. "Hard" braking and turning on the street is in no way comparable to the track, yet the pressure was dropping and oil light came on. which had me thinking something is definitely not right, especially for a sports car. After adding some oil, the oil pressure is way better now.
Old Jan 3, 2008 | 06:50 AM
gothchick's Avatar
gothchick
I'm not sure about the oem oil pressure sending unit, but the oem water temp sensor only polls every 60 secs.
Old Jan 3, 2008 | 09:18 PM
mthreat's Avatar
mthreat
Wow.. interesting. How do you know this? Maybe the Uprev guys can change it to poll more often.
Old Jan 4, 2008 | 05:32 AM
gothchick's Avatar
gothchick
^^^ Jeremy @ Performance Factory told me when I was there... I haven't verified in the FSM/ESM though...
Stevo Z
Oct 3, 2015 09:14 PM
