Bucking at 2300rpm
Old Mar 25, 2008 | 12:50 PM
  #41
sanmariblue350's Avatar
sanmariblue350
so any new information on this problem? i took my 350z in to have the clutch replaced and to have the service tech look at this problem. but woulndt you know it, the car didnt buck when they drove it. and the day i get it back from the dealer with the "nothing seems to be wrong" answer it F'ING BUCKS!@#! so im taking it back again tomorrow 3-26-08
is there a way if this continues to happen after multiple visits to have this car ruled a Lemon and get resolved? was trying to read up on lemon law stuff for texas, but all that legal jargon is cornfusing for me
Old Mar 31, 2008 | 10:02 AM
  #42
blasian's Avatar
blasian
I have no idea dude. I STILL haven't fixed it but then again, I haven't gone to my buddy's to swap parts to diagnose the problem.
Hopefully soon I will get a chance.
Old Mar 31, 2008 | 10:56 AM
  #43
rhythmnsmoke's Avatar
rhythmnsmoke
Originally Posted by blasian
That would be the culprit.... I have never noticed it doing it in neutral and reving on it. Then again, whenever I rev in neutral, it's a hard rev. I will try it today to see if that happens to me in neutral too. It's really freaking annoying. And it doesn't sit well with me to know a 2007 Z is showing the same symptoms. This makes me think twice about getting another Z after I sell the one I have.
Old Oct 22, 2008 | 06:35 PM
  #44
bucci's Avatar
bucci
I find that mine does it right about when the engine is warmed up and the temperature and oil gauges are normal. Then it will buck for a short while and then stop. It all started when I had my last oil change. Think it might have something to do with that?
Old Oct 22, 2008 | 06:38 PM
  #45
blasian's Avatar
blasian
Update... So I got a new motor through NNA and I still have the problem so I'm thinking it could be the coil packs. They reused my old ones... I'm going to try to swap with a friend to see if that gets rid of it.
Old Oct 22, 2008 | 08:05 PM
  #46
Cass007's Avatar
Cass007
I saw the vid and I have it too. 05 Z with a TN single. I thought it was the Utec or clutch, but this thread seems to rule this out. I have 650cc injectors and fuel return as well, but stock coils. Mine seems to want to buck at appx 35 mph cruise in third, just off of tip in on the pedal. SUX
Old Oct 22, 2008 | 08:09 PM
  #47
blasian's Avatar
blasian
Yeah, I've already changed my clutch and flywheel and have the same issue. It's more noticeable due to the light flywheel
Old Nov 5, 2008 | 05:37 PM
  #48
bucci's Avatar
bucci
I think I may have found a work-around. I'm not sure if it will work for everyone, but it works for me.
I found that when I start my Z from a cold start, the rpms shoot up to 2000 rpms, they drop down to 1500-1750 rpms for a few seconds, and then back up to 2000 rpms. After a few minutes the rpms slowly lower to the 1000 range as the engine warms. What I noticed is that when the rpms dip down for the few seconds, the exhaust sounds similar to when it bucks. So, my solution is to just tap the gas pedal for a brief second when the rpms begin to dip to bring them back up to the ~2000 range. It'll stay at 2000 and then slowly go down as the engine warms. No more bucking.
Let me know if it works for you...
Old Nov 6, 2008 | 03:02 AM
  #49
rhythmnsmoke
I will have to check some of these solutions, but I don't recall mines doing the same things. It just happens to buck at the same range.
Old Nov 7, 2008 | 03:03 PM
  #50
BiGGD198's Avatar
BiGGD198
does it only happen when its cold?
Old Nov 7, 2008 | 04:03 PM
  #51
rhythmnsmoke
^^For me...no. Happens cold or warm. I did not notice at all until After the clutch and light weight flywheel. Maybe the flywheel made it more pronounced.
darkgt
Dec 9, 2015 02:04 PM
Subw00er
Dec 2, 2005 02:42 PM
LA-Z
Oct 6, 2002 05:37 PM
