Looking for a taller gear...
Old Jan 16, 2008 | 08:45 PM
knight_white99's Avatar
knight_white99
Default Looking for a taller gear...
Hey guys (and gals),
I am looking for a taller rear end gear to run in the Silver State Classic Challenge. I have already swapped out my stock 3.53 gear for the 3.35 gear from and automatic Z.
I am looking for at least a 3.2 or lower number to run lower rpm at higher speeds. Ideally, I would like to find perhaps a 2.9 or something in that range so that I can achieve 200mph at reasonable engine rpms. I have not been able to find anything so far lower (taller) than 3.35.
Does anyone know where I can find anything like this?
Thanks in advance!
Old Jan 16, 2008 | 10:00 PM
z2g's Avatar
z2g
Sir may I ask why would you want to go 200mph?
Old Jan 16, 2008 | 10:23 PM
sentry65's Avatar
sentry65
the burninator
he said:
Originally Posted by knight_white99
I am looking for a taller rear end gear to run in the Silver State Classic Challenge....
Old Jan 17, 2008 | 12:59 AM
z2g's Avatar
z2g
Oh my bad!!! Guess I should read more carefully next time. well I've never heard of anyone going lower than the 3.3.
Old Jan 17, 2008 | 04:40 AM
App6MT's Avatar
App6MT
I thought taller meant faster acceleration and shorter meant higher top end.
4.11 > 3.55
Tall > Short
Old Jan 17, 2008 | 06:22 AM
sentry65's Avatar
sentry65
the burninator
4.11 > 3.55
Tall > Short
nope
opposite
Old Jan 17, 2008 | 08:18 AM
ke0ki2k's Avatar
ke0ki2k
what kinda setup are you runnin anyhow? I've read about a 3.2 gear on *********.com
Old Jan 17, 2008 | 02:06 PM
knight_white99
I am running the 3.35 now for the high speed events. Where did you hear about the 3.2 gear? Please PM me - the filter here covers your ???????.com website.
Old Jan 17, 2008 | 03:09 PM
redlude97's Avatar
redlude97
Couldn't you alter the tire size also to achieve an effectively taller gear?
Old Jan 17, 2008 | 03:12 PM
iStan's Avatar
iStan
ZR
^True, but for the OPs purpose, I think he can only go so far down in tire sizes
Old Jan 17, 2008 | 03:38 PM
ACEMAN's Avatar
ACEMAN
Master
Try this link.
Its a list on all Final drives for Nissan vehicles
http://www.nicoclub.com/Greg/ratios.html
I am running 4.083s in my car and they came out of a
Nissan Frontier
2005-2007 King Cab M/T 2.5L
C200
4.083
So maybe the
Nissan Frontier
2006 A/T 4.0L 2WD
C200
2.937
Will work for you
Hope this helps
Todd
Old Jan 17, 2008 | 08:01 PM
knight_white99
Originally Posted by aceman
Try this link.
Nissan Frontier
C200
4.083
So maybe the
Nissan Frontier
2006 A/T 4.0L 2WD
C200
2.937
Will work for you
Hope this helps
Todd
Now there's the kind of help I'm looking for!!!
Thanks, Todd! I will definitely check into those.
Old Jan 17, 2008 | 08:38 PM
Get_Zwole's Avatar
Get_Zwole
dude if you do this you gotta get a vid pleeaaassseeee
Old Jan 18, 2008 | 05:00 AM
knight_white99
If I can get a 2.937 gear, it will definitely happen. And I already have the video mount in my car.
But I am sure that I would not have the first "street legal" 350Z to top 200mph. SOmeone must have already done it by now...???
I think I have the power to do close to 220mph, just not the gearing.
Old Jan 18, 2008 | 08:06 AM
gabez33's Avatar
gabez33
How much HP do you need to reach those speeds? Cause I know its not all in the gearing
Old Jan 18, 2008 | 09:39 AM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
about 450whp plus ... well at least
Old Jan 18, 2008 | 11:06 AM
Q45tech's Avatar
Q45tech
The 2002 Q45 had a weird low economy diff gear at launch 2.93?
" For 2003, a new, higher numerical final drive gear ratio of 3.133:1 is utilized for better acceleration feel."
Old Jan 18, 2008 | 11:41 AM
ACEMAN's Avatar
ACEMAN
Master
Noprob,
Hope the info helps you out some. Not sure if it will work, but its worth looking into.
Later
Todd
Old Jan 18, 2008 | 12:21 PM
knight_white99
Check out this webiste. Enter your data and you can compute a top speed.
Most of the 350Z specs are easy to find. If you have a dyno plot that you can copy, it is pretty accurate. A lot depends on aerodynamic drag at high speeds.
http://vlsicad.ucsd.edu/~sharma/Potpourri/perf_est.html
Old Jan 18, 2008 | 02:18 PM
knight_white99
Noprob,
Later
Todd
Todd,
Did the ring and pinion fit your Z pumpkin/diff with no modifications? Are you running an open diff, stock VLSD or some other LSD?
