Ok this worries me
Old Jan 22, 2008 | 11:32 AM
abeklipse's Avatar
abeklipse
Default Ok this worries me
Now this only happens when the car has been warmed up and driven for a bit. The sound can only be described as a tick that sounds like a "pilot light ignition spark" found in gas heaters and stoves, kinda random with no real pattern to it. I've noticed this on older cars after parking where you would hear random clicking after shutting off the engine. Any ideas to what this could be?
Old Jan 22, 2008 | 11:52 AM
playa6tnine's Avatar
playa6tnine
is it kind of like a hissing sound?
Old Jan 22, 2008 | 01:40 PM
undrgnd's Avatar
undrgnd
It's the heat shields and other (usually) exhaust components cooling down. No worries.
Old Jan 30, 2008 | 08:26 PM
PhiSig's Avatar
PhiSig
Wheel Whore
Post pics of the new ride!
Old Jan 31, 2008 | 04:32 AM
Reality350's Avatar
Reality350
Have you checked your oil level?
Old Jan 31, 2008 | 04:35 AM
Sean's Avatar
Sean
Originally Posted by dave079
I am sure its the sound of metal contracting on cooldown.
What he said...
Old Jan 31, 2008 | 05:57 AM
terps's Avatar
terps
catalytic converter more specifically, I don't get that noise anymore.
Old Jan 31, 2008 | 06:26 AM
z350boy's Avatar
z350boy
If it is a constant "tick...tick" sound as the engine is running that is the sound of the valves. If it is noticeable it may be an indication of low oil. I would suggest you allow the vehicle to get to operating temperature; then check the oil level. Then monitor it every time you use the car for the next six times. Then compare your oil levels to see if there is a big variation in levels. If there is a problem you should see the level start to drop between the first measurement and the last.
Old Jan 31, 2008 | 07:13 AM
007|350Z's Avatar
007|350Z
+1 To all the posts stating that it is the engine and exhaust components cooling down. That is what it sounds like to me, standard vehicle noises, no worries.
Old Jan 31, 2008 | 08:18 AM
cheshirecat79's Avatar
cheshirecat79
I had this same issue and it ended up being the catalytic converters cooling off. This is the case, especially if it sounds like it's coming from under the car towards the engine bay (where the cats are).
waldo36
Sep 20, 2015 09:13 PM
PureR3d
Sep 10, 2015 06:23 PM
ddegrande21
Sep 6, 2015 11:15 AM
RP-350Z
Jul 20, 2002 07:47 AM
