differences between FWD Vq35de and Rwd Vq35de
Originally Posted by MardiGrasMax
Maximas are slow.
Originally Posted by eyecon7
i know there is an all motor VQ35DE running 11's or 12's...... for a maxima thats pretty good....... but yea RWD drive is better... thats my point....
Honestly, IMO that doesn't even compare to the guy on the org who ran 12's with an all motor VQ30.
Originally Posted by pmohr
Jime ran a 12.4 with a VQ35 and 4AT, all motor.
lol at Mardi & Hal saying Maximas are slow...
Originally Posted by DandyMax
^^^Rumor has it that guy is now working on a 3.5 project... :wall:
Could've sworn it was you, but I was at work (AAM
Anyway, side by side as promised:
Last pics kind of sucks, but eh. All are hotlinked to the full res versions.
All are taken with the blocks positioned in the same exact way (though the FWD 3.5 has torque plates on it).
About to head over to the org and PM Nismology to make this a sticky...
Originally Posted by Hal@IP
+1
Nice pics pmohr, thanks for the side by side
Just in case anyone cares to see it, here's my thread in AM on the org: FWD vs RWD VQ35 Differences (Lengthy)
What mods were they running & what kind of power were they putting out?
Edit: for the video click here.
Set some new PB's yesterday at the track. The "little" old 3L went 12.83 @ 106.90 mph. On another pass it trapped 108.26 mph (on a 12.90 ET).
Scary thing is, there's a few tenths left in it yet. The car's only roughly tuned and I had a lot of problems with it breaking up at high rpms due to sudden lean-out. I'm lucky these are tolerant engines and I'm N/A or the motor would have blown. Thankfully I had the knock sensor working overtime. It was unexpected, the night before I wasn't seeing that as much doing some street tuning, thought it was safely rich so I need to look into it, might be a fuel pump/supply issue or it could be the stock ECU switching tables on me again (don't even ask how many problems the stupid Nissan ECU has caused me). Also, my launches and shifts were a bit rusty shall we say, not having raced in a year... that plus a shifter **** that's stripped and comes right off the shaft - so mostly pulling 1.8x sixty foots, worse than the mid 1.7's I'm used to. I think I'm going to change my launch technique a bit with this setup now too, it needs to be launched a bit higher than last year's.
Considering all the factors, I'm thinking this car should be able to do 12.6x and trap 109. I never had 1 solid pass all day yesterday. Even the 12.83 and 12.90 were glitchy. Others were worse; for example the car crapping out up top turned a half-decent start on a 1.79 sixty foot into a 13.05 @ 94.57, and on another run it turned a 1.88 sixty foot into a 13.19 @ 88.77. ( at the trap speed)
Anyhoo, timeslip is below, and I have video footage which I'm just editing together and will post soon.
Ok here's the mods list (as of Sept 29/07):
VQ30DE-K Swap
VQ35 Rev-up oil pump w/ low pressure cut off switch
VQ35 JWT S1 cams (JDM knockoffs)
VQ35HR valve springs and retainers, double shimmed
Mild head "work" (NOT ported though)
Unorthodox flywheel
Exedy Stage 1 clutch
Greddy EManage Ultimate
Pathfinder TB
Motostorm UDP
Custom intake w/ MAF delete
Cattman headers/y-pipe/catback (plus cutout)
Low temp T-stat
Walbro fuel pump
Returnless fuel rail w/ adjustable FPR
Some weight reduction
K-Sport coilovers
Belts: alternator only
Full ES bushing set and motor mounts
24.5x8.5x15 M&H slicks on 15x7 Kosei's
Courtesy STS
I have other cosmetic mods but that should be most of the "go" stuff...
VQ30DE-K Swap
Unorthodox flywheel
Pathfinder TB
Motostorm UDP
Low temp T-stat
Walbro fuel pump
K-Sport coilovers
Courtesy STS
