AC problems?
Old Feb 29, 2008 | 06:33 PM
misterlv's Avatar
misterlv
Default AC problems?
okay its winter now but last summer i tried to use my ac and it will work sometimes and then most times it didnt work. it would just blow hot air. this is a must in my car to have. so i turned it on and pop the hood. the compressor did not engage with the belt. i dont think its the ac compressor though. is anyone else having this problem or is there someone who knows with experience about this? it be greatly appreciated.
Old Feb 29, 2008 | 06:54 PM
pmohr's Avatar
pmohr
Is the system charged? If there's too low/high of a pressure in the system, the compressor won't cycle (safety feature).
Old Feb 29, 2008 | 07:15 PM
misterlv's Avatar
misterlv
how do i know if its charged or not?
Old Feb 29, 2008 | 07:19 PM
pmohr's Avatar
pmohr
Some cheap gauges from an auto parts store will let you know, basically. If it doesn't have any refigeramt in the system, it's best that you should take it to a shop to have it fully evac'ed and recharged with dye to see where it's leaking from (assuming it has a large leak, it's 'normal' to leak a small amount over time).
I wouldn't recommend doing it yourself with cans, judging by system pressure isn't very accurate at all.
Old Feb 29, 2008 | 07:30 PM
misterlv's Avatar
misterlv
how much would they charge to fill?
Old Feb 29, 2008 | 07:39 PM
pmohr's Avatar
pmohr
Individual shop prices can vary widely. Call around, look on shop's websites (if they have one), etc.
Old Mar 1, 2008 | 11:45 PM
Eazzy's Avatar
Eazzy
A/C probs have to be addressed 100% there are no short cuts. First you have to do a gauge reading. If your Low side is above 45ish and your Hi side is below 200 + ish then you have a prob. That prob is solved from starting from Point A. Bring down the system. run a vacuum test, if you lose Vac, replace all o-rings. Run Vac again, if it holds then your cool. Open system, flush, replace accumulator, vacuum and charge. If it loses Vac after O-rings are replaces CORRECTLY, your Compressor mite be leaking. Replace it. If you Charge and get screwy readings (low side hi and Hi side Hi) your Expansion valve is trashed ---replace.
Its a damn can of worms ---I tend to just bite the bullet and unless I have a compressor that is obviously oily (leaking) I open, replace accumulator (always a good thing) the Expansion valve (contaminated) Flush, Vac and Charge
Old Mar 2, 2008 | 06:52 AM
undrgnd's Avatar
undrgnd
AKA 'the methodical, shotgun approach'. Unless some of the components are hard to get at (usually, the defective ones), it's a good approach.
Old Mar 2, 2008 | 07:06 AM
Eazzy's Avatar
Eazzy
In the Z , the accumulator is easy, the comp is a little bit of a pain, unless your turboed ---then a big pain. And the expansion valve is always a pain
And actually judging by system pressure is very accurate is you take into account ambient
Old Mar 2, 2008 | 10:08 AM
misterlv's Avatar
misterlv
thanks for the info fazzy. and everyone else.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
