Carbonetic LSD
Old Mar 1, 2008 | 11:54 PM
JETPILOT's Avatar
JETPILOT
Default Carbonetic LSD
Is the Carbonetic LSD a direct replacement for the OE LSD? Just a simple swap?
JET
Old Mar 1, 2008 | 11:56 PM
rookie's Avatar
rookie
Yes, uses the vlsd flanges.
Old Mar 2, 2008 | 12:29 AM
JETPILOT's Avatar
JETPILOT
Anything else I should purchase new for the swap?
JET
Old Mar 2, 2008 | 12:32 AM
anotheraznguy's Avatar
anotheraznguy
some diff fluid...
also good would be a nismo rear diff cover.
also prepare to get dizzy with the break in...
then change oil again.
Old Mar 2, 2008 | 08:28 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if the car has any meaningful mileage (over 20k or so) Id also do new rear bearings and seals at the same time
Old Mar 2, 2008 | 10:25 AM
__jb's Avatar
__jb
Z + Rear Seat
JET
Get a can of the genuine ATS fluid. It's important to change the fluid around the 300 mile mark and break in the diff correctly. After that, you can expand the fluid changes to every 3000 miles... just do it with the oil.
From what I've read/heard, it's especially important to break in the diff with their lube. You'll get break-in instructions with the diff.
Changing the diff is also the perfect time to change the final drive ratio if you're thinking about doing that.
Old Mar 2, 2008 | 10:28 AM
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by anotheraznguy
some diff fluid...
I wasn't aware that you had to do the figure 8 thing with a carbon diff.
Old Mar 2, 2008 | 10:21 PM
anotheraznguy
i dont know.. maybe someone can chime in on that piece..
Old Mar 3, 2008 | 07:52 AM
__jb's Avatar
__jb
Z + Rear Seat
I did the figure eight thing for 20 minutes and then drove straight home and drained the fluid. I wanted to drain the fluid while all the carbon particles were still suspended in it. I used a large parking lot behind our office and did it on a Saturday afternoon.
I seem to remember the instructions saying you could just drive the car for 300 miles or so and break it in that way, but I forget the specifics of that.
Carbonetics makes a fine diff... it works well... it's quiet and doesn't clunk at all... The only slight negative is that you have to change the fluid a bit more often than normal... I'm happy with mine.
Old Mar 3, 2008 | 12:11 PM
ProjectPSI's Avatar
ProjectPSI
Break in for Carbonetic does require you to do the figure 8 for 15-30 minutes and then around 200 miles of street driving is recommened. Make sure you use the right fluid and change it after the break in.
Old Mar 3, 2008 | 01:13 PM
__jb's Avatar
__jb
Z + Rear Seat
Here's the break-in info direct from the Carbonetic's web site.
Old Mar 6, 2008 | 04:45 AM
rcdash's Avatar
rcdash
Well I guess there's a slight difference between km and miles - lol. Thanks for posting jb. Kind of a PITA to do it every 1800 miles.
Who thinks doing it every 3k miles is ok? Damn, for every 1800, I might get a fumoto valve on there for quick drain and refills - thoughts?
Old Mar 6, 2008 | 08:49 AM
ProjectPSI's Avatar
ProjectPSI
It really depends on your driving. Its perfectly ok to do it every 3,000 miles, same as an engine oil change. 1,800 is a little overexagurated number.
Old Mar 6, 2008 | 09:51 AM
__jb's Avatar
__jb
Z + Rear Seat
My plans are also to do it with the oil changes.
I talked to a couple of people that I trust and they both suggested 3000 mile intervals... i.e., with the oil changes.
Old Mar 6, 2008 | 12:04 PM
helldorado's Avatar
helldorado
One of the perks of the Quaife. Just over 10k miles and I've been considering changing oil since its been about a year and a half. But I don't have to.
Old Apr 7, 2010 | 08:33 PM
specialist's Avatar
specialist
for the carbonetic lsd what other fluid can you put in instead of carbonetic fluid
Old Apr 8, 2010 | 07:40 PM
rcdash's Avatar
rcdash
I use Redline 75W-90. Motul gear oil works also. Amsoil has one also.
Old Apr 8, 2010 | 07:48 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Its been around 300miles since I put in my os giken but there is no break in process. Should I change the motul oil?
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
