replacing the ECM??
Old Mar 3, 2008 | 07:45 PM
str8dum1's Avatar
str8dum1
Default replacing the ECM??
Hey guys,
My stock ECM is part #MEC31-901-A1 2Z11
Does that mean, that I need to find a used unit with the exact same part #? Or can I get a ECM that matches up to the MEC31-901-A1? or MEC31-901??
There are a bunch on ebay and car-part.com with multiple variations, but none exactly the same all the way thru
The car is a 2003 G35 6mt coupe.
Thanks!
Old Mar 4, 2008 | 03:21 AM
DavesZ#3's Avatar
DavesZ#3
If you want to guarantee that it works correctly, then get one with the same part number. Check out this page....
http://www.courtesyparts.com/betasit...14_715_743_747
As you can see, there are a lot to choose from, different years, different models, different transmissions, etc. For example, it won't do you any good to get an ECU for a AT car when yours is MT, etc.
Old Mar 4, 2008 | 06:46 AM
__jb's Avatar
__jb
Z + Rear Seat
You'll also have to get your keys burned into your new ECU.
Old Mar 4, 2008 | 07:05 AM
gothchick's Avatar
gothchick
Don't forget about making sure the BCM and other subsystems can also talk to the new ECU...
Old Mar 4, 2008 | 08:30 AM
str8dum1's Avatar
str8dum1
ya i know about the keys. Used ECMs are under $400 as a new one is over 1k$ so I wanna explore used 1st.
doesnt seem like anyone has really replaced their ECM. Maybe a dealer would know? Local shop isnt that helpful though.
Old Mar 4, 2008 | 08:57 AM
str8dum1's Avatar
str8dum1
I found the infiniti part #23710-Am703 for $663. Dealer reprograms it for $100.
Only problem is that there is no reference to the MEC31-A901-A1 number though.
He said that was the part # based on my VIN, but that part # seems pretty generic in the description based on the multitude of MECxx-xxx-xx #'s you see on the web
argh... I wish someone knew what #'s etc were critical
Old Mar 11, 2008 | 07:13 AM
str8dum1's Avatar
str8dum1
Well i was told that Technosquare uses the big 2 digit code on the ECU as the identifier. I found a used computer with that same 2 digit code but a different MEC#. Its from the same year and tranny. Fingers crossed it works.
Old Jul 21, 2020 | 02:24 AM
SmokieXSilverZ's Avatar
SmokieXSilverZ
Yea I’m looking at doing the same howd it go for you?
Old Jul 21, 2020 | 07:26 AM
seymore4's Avatar
seymore4
Professional
You realize that post was from 12 years ago?
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
