Launch Control for 5AT auto transmission?
Old Mar 7, 2008 | 09:35 PM
gregom's Avatar
gregom
Default Launch Control for 5AT auto transmission?
Is there a way to get a proper launch control setup going for the Z auto tranmissions? I know Lambo's and Ferrari's have this on their paddle-shifter setup. Maybe it could be modded into the ECU?? Putting the brake on and burning rubber isn't always the best option.
Don't bother replying if you just wanna say get a proper manual.
Old Mar 7, 2008 | 10:40 PM
iceman21_23's Avatar
iceman21_23
you can preload by stepping on the break and the gas till around 3200-4500 rpm before u start burning rubber this tends to help ive noticed
Old Mar 8, 2008 | 02:49 PM
GrayG35's Avatar
GrayG35
by the time we get up to about 3k the rubber is alredy burning lol. if someone came out with something like this, id be first on that list.
Old Mar 8, 2008 | 03:58 PM
gregom's Avatar
gregom
Preloading wastes tires... I know it can be done, the transmission just needs to be told electronically to disengage the clutch when in 1st gear and launch control is initiated, maybe something like pushing the shifter forward would engage the clutch. Essentially doing the same thing as dumping the clutch on a manual.
Anyway i'll keep dreaming, guess i'll have to find a Ferrari, lol.
Old Mar 8, 2008 | 07:22 PM
GrayG35's Avatar
GrayG35
lol fu k it and neutral slap that b1tch haha jk... well i guess you could try it and tell us how many times it works before something goes out so that way we know to do it one less time.
Old Mar 8, 2008 | 07:43 PM
jgregory124's Avatar
jgregory124
good question
Old Mar 8, 2008 | 10:35 PM
ladyzed's Avatar
ladyzed
Load up the torque converter with brakes on, just so the rpms stay just before the tires let loose.
This is also a good way to know where the factory stall is at (@ what rpm)
I have a 3000rpm stall converter in my 72, if anyone cares. Takes a second to 'spool' up.
Old Mar 9, 2008 | 12:11 PM
jgregory124
my 07 starts to spin when ever hit the gas hard.......i have 2000 stall and it is worst when i hold the brake and rev to 1600 rpm.......spinns with some wheel hop
Old Mar 9, 2008 | 12:20 PM
rcdash's Avatar
rcdash
Using a two step on an EMS (like the Haltech's auxiliary rev limiter) to load the drivetrain is the only thing I can think of that would work in a relatively similar fashion. Instead of clutch release, you'd have to tie the signal in to the brake release... I'd think things through though to make sure it doesn't exhibit unintended (dangerous) behavior.
Old Mar 9, 2008 | 05:34 PM
SniperHunter's Avatar
SniperHunter
Torque it to 2500RPM, and don't flog on green. You'll want to apply 3/4 throttle, and after all torque has been applied (~4500RPM) full throttle. Learning how to feather also helps tremendously. Ultimately, practice makes perfect.
Old Mar 10, 2008 | 05:26 AM
coachk's Avatar
coachk
+1..you beat me to it as always. 2step
Not trying to be disrespectful, but alot of useless info in this thread
Per Nissan specs : TC 2650rpms-2900rpms.....
Old Mar 10, 2008 | 12:50 PM
MardiGrasMax's Avatar
MardiGrasMax
What we need is a trans brake set up. I beleive on the domestics they engage 1st and reverse at the same time, gas it to launch rpm, then push a button and reverse releases. This is like dumping the clutch on a MT but the torque converter absorbs the shock which is a lot easier on the driv etrain than a normal clutch drop in a MT.
SOME ONE PLEASE MAKE THIS FOR US!!!
Old Mar 10, 2008 | 03:54 PM
coachk's Avatar
coachk
^^^ check with Injected Performance....
Old Mar 10, 2008 | 04:41 PM
Vader007's Avatar
Vader007
Its taken five years for us Auto guys to get any love from the Z tuner companies, hopefully one of the reflash companies or Cobb will get into the tranny control area since it is controlled by the ecu. It would be nice to adjust shift points and launch control through a program! I think its just a matter or time before someone does this as there are more and more options coming out for the auto guys: paddles, valve bodys, TQ's and so on!
Its another are of oppurtunity for the tuners to make money and close the gap on performance between the 6mt guys and us.
Come on Technosquare, AAM, Cobb and Cipher......hear the calling!
Old Mar 10, 2008 | 04:54 PM
coachk's Avatar
coachk
I think the Haltech does the things you mentioned..I'll let Raj (RCDASH)chime in
Old Mar 10, 2008 | 06:14 PM
gregom's Avatar
gregom
Well it would be nice to get above 3000 RPM, and right now you cant. It would be awesome if someone can mod the ECU to do this.
Old Mar 10, 2008 | 07:52 PM
rcdash's Avatar
rcdash
You can increase stall speed by upgrading the torque converter. My stall has been increased from 2600-2900 up to around 3200. There is no transbrake enabled valve body available for this transmission to the best of my knowledge. The Haltech can hold a certain rpm with the gas full depressed (aux rev limiter), which will release once an external trigger activates (usually clutch release, but it could be manual trigger or brake release). Keep in mind that the tranny temp will skyrocket as the TC spins and you hold the car in place. You get immense torque multiplication though. Don't do it for long - it's not as safe as a 6MT 2 step, where you can sit there all day with the pedal to the floor before dumping the clutch.
Old Mar 10, 2008 | 08:01 PM
gregom's Avatar
gregom
Your talking burning tires still... i'm not. A 6MT can do burn tires at a standstill just like we can if they are good with heel/toe. I want a true launch control, I know its possible. Someone here has to have knowledge when it comes to reprogramming the ECU. Maybe its not something easy to do, but I would think its just a command the ECU gives the trans.
Does anyone know if the GTR has a launch control system?
Old Mar 10, 2008 | 08:56 PM
Bill_the_Cat's Avatar
Bill_the_Cat
One Whacked Cat
The GT-R does have launch control. Edmunds/Insideline reviewed a privately owned sample with 1500+ break-in kilometers. Launched the sucker to the tune of 3.3 sec to 60 mph twice, and this was on a not-fully-optimal surface! They set everything to race mode and turned off VDC.
http://www.edmunds.com/insideline/do...ticleId=124017
Sick! is all that ....
Old Mar 10, 2008 | 09:05 PM
Show us how it is done here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html.
