Slight hesitation about 4K RPM after Amsoil NanoFiber drop in?
Old Mar 18, 2008 | 08:50 PM
Teufel's Avatar
Teufel
Default Slight hesitation about 4K RPM after Amsoil NanoFiber drop in?
After driving car for 20min or so today (waiting for oil to heat up), I was a little spirited 10-50mph @ 5K RPM. From 4-5K the engine seemed to stutter VERY slightly....almost like it wasn't getting enough air/gas? The peddle was not to the floor.
Any ideas? Thanks guys!
Old Mar 18, 2008 | 10:02 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
is that an oiled filter?
Old Mar 19, 2008 | 07:38 AM
06CPV35's Avatar
06CPV35
^ No, it's nano fiber paper.
Know someone who just switched to this filter and started to ping.
It was suggested for that member to reset his ECU to learn the new air flow being supplied and ECU will adjust off the bat, rather than learn new flow over time.
The same may be OP's case. Try a ECU reset and let it compensate/learn the new air flow immediately and see if sutter goes away after that.
Old Mar 19, 2008 | 08:09 AM
GrayG35's Avatar
GrayG35
this happens to me too, but i dont have that filter.
Old Mar 19, 2008 | 10:07 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If it continues pinging or hesitating, I would definitely get a dyno. $30ish and it will diagnose any power cutting out easily. See what's going on with your AFR... don't get a dyno without AFR.
Old Mar 19, 2008 | 11:47 AM
06CPV35's Avatar
06CPV35
^ Agree...AFR's with Dynos go hand in hand.
Old Apr 19, 2008 | 10:02 PM
Teufel's Avatar
Teufel
Thanks for the responses. Really think it could be from a air filter? That's amazing...
Almost makes me want to switch back!?! Are the Z's that sensitive to adjustments?
Could this be a sign of something more serious?
Old Apr 19, 2008 | 11:08 PM
Tac-M's Avatar
Tac-M
if you have never cleaned your MAF sensor i would suggest you try that. pull it out ( secure bit is needed) and spray it with MAF sensor cleaner. also clean your throttle body. and then do idle air learning procedure found here http://www.technosquareinc.com/350reset.htm
Old Apr 20, 2008 | 12:53 AM
Teufel's Avatar
Teufel
Thanks Tac!
I am installing MD, Exhaust, HFC at the same time. I will prolly throw those two items in as well.
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
ATI ProCharger
Mar 9, 2004 07:30 AM
hfm
Oct 8, 2003 12:31 PM
tyoung88
Sep 9, 2003 10:52 AM
