Oil cooler prevent oil burn?
Old Mar 23, 2008 | 09:20 AM
ke0ki2k's Avatar
ke0ki2k
Default Oil cooler prevent oil burn?
well I have my V2 in and after runnin the dragon last night I figured out its burnin oil. Would a greddy or stillen oil cooler help keep the engine from burnin oil under hard use? input?
Old Mar 23, 2008 | 09:35 AM
SpoilsofWar's Avatar
SpoilsofWar
No... An oil cooler does exactly what it sounds like - cools oil.
If you are burning oil it is because oil is making its way into the combustion chamber, either up past the piston rings or down from the heads. Lower oil temps from an oil cooler present will not prevent this.
Old Mar 23, 2008 | 09:53 AM
terrasmak's Avatar
Your is an 06 , take to to the dealer for a new motor.
Old Mar 23, 2008 | 11:14 AM
ke0ki2k's Avatar
ke0ki2k
Kinda figured that, thought dropping the oil temperatures might help keep it a little thicker and keep it from passing the rings and seals. I know Terra, I already have the V2 in it. it consumed a bit of oil after I ran up through the dragon a few times...waitin to see if it will continue with normal driving after switching to synthetic. If I end up having to get another engine swapped in I might be looking to trade it in...
Old Mar 23, 2008 | 03:51 PM
JETPILOT's Avatar
JETPILOT
If you want thicker oil.... buy thicker oil.
JET
Old Mar 23, 2008 | 04:44 PM
SpoilsofWar
^ Pretty much.
Also, that sort of logic is a bandaid on a gunshot wound. If you are burning significant oil, a thicker oil will not save you.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
