Act street clutch and prolite flywheel installed
Old Mar 31, 2008 | 08:23 PM
dyno's Avatar
dyno
Default Act street clutch and prolite flywheel installed
First of all, I'd like to thank Adam at z1. I ordered the clutch on Wednesday all the way in California and needed it by Friday. Adam made sure I had it on time. The clutch feels great, the shifts are extremely precise. No extra noise detected during idle other then the normal 2003 z transmission sounds. The dump truck sound only shows up under 2,000 rpm. Very little sound is heard on first gear and a bit more on 2nd under 2,000 rpm. It's as annoying as a lot of people have made it out to be at all, and can be completely avoided as long as you maintain your rpm's above 2,000. Haven't done any rough driving with it yet as I am still breaking it in. One issue that I have is that my 350evo street shifter has started to rattle (audible above 4,000 rpm) a little bit after getting the new clutch installed. Isn't annoying as long as I hold onto the ****. Anyway, awesome clutch! definitely recommend it.
Old Mar 31, 2008 | 08:33 PM
dyno's Avatar
dyno
Forgot to mention that the clutch is actually lighter then the stock 2003 clutch which was extremely heavy. It feels a bit more springy when you let go to get into gear. I also like how the engagement is closer to the ground now
Old Mar 31, 2008 | 08:35 PM
Denum's Avatar
Denum
Congrats.
Old Mar 31, 2008 | 09:10 PM
dyno's Avatar
dyno
thanks
EnjukuRacing
Sep 30, 2015 06:55 AM
