Auto Tranny Shift Shift Problem
Old Apr 7, 2008 | 07:32 PM
abushong504's Avatar
abushong504
Default Auto Tranny Shift Shift Problem
Hey guys, I have an 06' automatic Z with the manual mode. The other day I was driving and decided to take off pretty fast, when the needle on the tach reached redline, it would not shift (keep in mind, it was in D mode not the manual mode). I slowed down and the RPM slowly decreased but it would never shift to a higher gear. I even tried putting it into manual mode to shift it myself, and still nothing. I eventually turned the car off and the problem was fixed when I turned it back on.
I did some research on here and found a couple similar problems but nothing exact. I was just curious if this could be caused be any particular reason, should I get it checked, or do you think it was just a fluke? Thanks for the info. in advance guys.
Old Apr 7, 2008 | 09:00 PM
gregom's Avatar
gregom
Mine has done that a couple times too, seems to only happened when I had a little drift going, but I only do that in the manual mode so it wont shift on me in the middle of the slide. Were you going in a straight line?
Old Apr 7, 2008 | 09:06 PM
lionheartednyhc's Avatar
lionheartednyhc
Thats no good. My 6MT never does that
Old Apr 7, 2008 | 09:10 PM
clarkemtp's Avatar
clarkemtp
Faaaaaaaaaaaaaan-tastic. But that "contribution" really doesn't help the OP, ummm, at all. Mmmmmkay.
abushong504
lol yes, that is no good. i was taking off from a start on a straight line, but the tires did spin, so maybe it has to due with the loss of traction
Old Apr 7, 2008 | 09:14 PM
ZPatrick's Avatar
ZPatrick
but our manual too weak and too many other problems too
Old Apr 7, 2008 | 09:15 PM
marques1's Avatar
marques1
lionheart the auto z is way more reliable than the 6speed so holla back when your on your 2nd or 3rd transmission when the auto is still running strong, holla lol.
Old Apr 7, 2008 | 09:17 PM
Teufel's Avatar
Teufel
My Auto has never done that. Only 33K on it, but still feels decently strong.
Old Apr 7, 2008 | 09:41 PM
Donsred350Z's Avatar
Donsred350Z
I've heard that you can't power brake a 350Z 5AT past 3000rpms or it will shut down on you, maybe you when past this limit with wheel skiding making the computer in the 5AT think you were power braking and way past its limit.
Anyway like going to a Doctor saying it hurts when I do this, the Doctors reply is don't do that.
The 5sp ATs I've driven I've never had that happen and I've burned rubber all over the place in them.
Old Apr 7, 2008 | 09:53 PM
abushong504
Hmmm, that is interesting. Well, like I said it only happened once so hopefully that will be it. Thanks for the info guys. I did not know you weren't supposed to torque rev it passed 3000 RPMs. I'll keep that in mind ha for future references.
Old Apr 7, 2008 | 10:07 PM
mrg1981's Avatar
mrg1981
OP- I have a few questions for you. I might know the issue here.
1. Is your car convertible?
2. Did you hear the engine continue to rev higher or were you just judging by the needle position on the tach?
3. Did your car sit in the sun for a little bit before this occurred?
Old Apr 7, 2008 | 10:47 PM
Teufel's Avatar
Teufel
subscribing.....for what youre getting at
Old Apr 8, 2008 | 12:28 AM
mrg1981's Avatar
mrg1981
I might be way off track, which is why I asked him the questions first. I have an auto and there have been a few times that I didn't think it shifted when it should have. Upon closer inspection, it did shift, but the needle was stuck in place. This happens when the sun heats the black plastic behind the gauge (convertibles being more susceptible) and when that plastic expands, the friction holds the needle in place for a little bit.
Once again, I might be way off, but this sounds like what I experience once in a while myself.
Old Apr 8, 2008 | 05:30 AM
The Captain's Avatar
The Captain
I've had this happen before in manual mode. Got near the redline and tried to shift, but nothing happened. I pushed it again before it hit the redline... still nothing. I had to let off the gas till around 3k before it would shift up. Weird. (I know mine didn't shift too because the digital tach still displayed 1.) Lesson learned: Shift earlier in 1st gear. Haven't had the problem since.
Old Apr 8, 2008 | 09:02 AM
Donsred350Z
Now we are talking standing on the brakes and reveving the engine building rpms and burning rubber. I've had them reveved almost up to redline going up to to 135mph quickly (I know the car will do more but I'm a chicken) and shifting so only when you power brake or anything like that does the 5spd AT safety measure occur.
Old Apr 8, 2008 | 11:11 AM
Z04's Avatar
Z04
can't say i ever had that happen before, though i did forget once i was using manual shift and banged the redline in first (duh) but that was like 2 years ago and no problems at all.
Old Apr 8, 2008 | 11:39 AM
rcdash's Avatar
rcdash
Just to be safe, I would check tranny fluid as per the FSM or have the dealer do it. You need to let the car warm up and use a lint free cloth (whatever that is).
Old Apr 9, 2008 | 08:58 PM
ladyzed's Avatar
ladyzed
But was funny as hell.
Uriyo_
Sep 8, 2021 08:46 AM
_bit
Oct 2, 2015 07:49 AM
