Is this normal?
Old Apr 22, 2008 | 05:54 PM
DeBru_Z's Avatar
DeBru_Z
Default Is this normal?
Installed my new plenum spacer and noticed oil sitting in the center section of the intake plenum. Is this normal? Thanks!!
Old Apr 22, 2008 | 05:59 PM
03aeroZ's Avatar
03aeroZ
a certain amount is normal, not sure how much that "certain" amount is though. I have heard of some of the 06s having puddles.
Old Apr 22, 2008 | 06:57 PM
DeBru_Z's Avatar
DeBru_Z
Okay, thanks. Sounds like it could be worse!
Old Apr 22, 2008 | 06:58 PM
sw150's Avatar
sw150
Not to go off topic. But are you going on saturday Phil?
Old Apr 22, 2008 | 07:18 PM
VQ35DESC's Avatar
VQ35DESC
get an oil catch can
Old Apr 22, 2008 | 07:25 PM
DracoLancet04Z's Avatar
DracoLancet04Z
really? i would figure oil in the intake = bad
Old Apr 22, 2008 | 07:26 PM
03aeroZ's Avatar
03aeroZ
its oil vapor condensation....this is why a catch can would assist with fixing the problem
Old Apr 22, 2008 | 08:03 PM
DracoLancet04Z
learn something new every day
Old Apr 22, 2008 | 09:12 PM
Hoooper's Avatar
Hoooper
yeah this is pretty typical on the 3.5's, like said before get a catch can or for a quick fix you can use a fram g3 fuel filter on the hose, make sure you use the clear though so you can check it
Old Apr 23, 2008 | 05:06 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
mine looked like that as well when i was installing my spacer but install a catch can and that should help
Old Apr 23, 2008 | 07:27 AM
gothchick's Avatar
gothchick
Yep, normal. A catch can will take care of most of it.
Old Apr 23, 2008 | 07:40 AM
CSF's Avatar
CSF
when i installed my spacer, i had about the same amount (maybe less) than you do.
Old Apr 23, 2008 | 09:56 AM
VO...'s Avatar
VO...
Administrator
+1
Old Apr 23, 2008 | 11:13 AM
SpoilsofWar's Avatar
SpoilsofWar
That looks mild actually, when I broke down my engine for my turbo build and removed that brass cover, there was much more oil sludge in there then you have pictured. My car is an 03 though, with around 60k on it, and I'm sure it had never been cleaned out previously.
Old Apr 23, 2008 | 01:14 PM
seekndestroy19's Avatar
seekndestroy19
they have a DIY for oil catch can on here also. I made one last year and it worked. Its simple to make and and had to clean it out like every other month.
Old Apr 23, 2008 | 07:46 PM
03aeroZ's Avatar
03aeroZ
just a thought, if you install a catch can, should you clean out the plenum? or will it eventually clean it self out? very curious about this.
Old Apr 23, 2008 | 07:51 PM
350ZTheStandard's Avatar
350ZTheStandard
Same thoughts as everyone else, do the homemade catch can that is posted on this site, to minimize this oil & sludge.
Old Apr 24, 2008 | 05:02 PM
DeBru_Z's Avatar
DeBru_Z
Thanks, everyone for the input/advice.
Old Apr 24, 2008 | 05:06 PM
Spork's Avatar
Spork
Might as well clean it since you're there.
I built my own catch can, seems to be working good. I gotta take the plenum off and clean out everything for the hell of it tho... Do I have to worry about messing up my gasket if I take it off just to clean it?
Old Apr 24, 2008 | 05:10 PM
03aeroZ's Avatar
03aeroZ
i can add the catch can in like 15min, taking off the plenum and everything would take much longer than that, so that is why i wanted to know if it was necessary.
