improving throttle repsonse?
Old Apr 29, 2008 | 07:34 PM
KhanMan's Avatar
KhanMan
So what is the consensus then?
Old Apr 29, 2008 | 08:43 PM
gregom's Avatar
gregom
Yeah I think the ECU is pretty restrictive with the throttle... after doing research upgrading the valve body, final drive ratio/diff, and ECU reflash will help a lot. I plan on doing this stuff myself once I get into some money...
Old Apr 29, 2008 | 10:29 PM
nismology1's Avatar
nismology1
Originally Posted by CSF
you may want to ask the reflashers (uprev, TS, cobb). uprev has implemented the "enhanced throttle control" which iirc allows the throttle to open up 100% immediately. i believe the stock ecu only allows the throttle to open up gradually. cobb is also planning to implement this in their future maps. they may have more info on this since i assume they've looked at the throttle tables
I bet you if they observed TPS voltage directly (instead of the via the data port) they would see that the throttle stays at 100% open and doesn't budge as long as the pedal is pinned. This has already been proven over on maxima.org.
Old Apr 30, 2008 | 07:27 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I measured the same on the dyno.
pslamp32
Feb 8, 2017 09:07 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
