Dealer Oil Question
Old May 1, 2008 | 04:37 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
5w30, 10w 30 -it won't make any meaningful difference between them - either works just fine
Old May 1, 2008 | 09:18 AM
dirty_215's Avatar
dirty_215
With the different weights it depends on location, climate, and the type of driving you do. In the winter time you don't want too think of an oil because it's not that great on the vehicle's internals. It's like your pistons and etc... are moving through syrup. Now in the heat you can go thinner or thicker, but depending on the type of driving you do. The harder you push your car the hotter the oil becomes and when you factor in climate you can thin your oil more than you think, and then the oil is no longer protecting your internals. So in the summer time you can mix your oil weights, like 4 quarts of 5 and 1 quart of 20 or whatever mix you need for your area and your style of driving, or you can just go one lighter weight.
Old May 1, 2008 | 10:30 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Lento
I took my car up for the first oil change today and told them to put Mobil 1 10W30 in. The guy said they didn't have Mobile 1 but they had Synthenol.....
When I got the slip back it said 5 quarts of Synthenol 5W 30
I went back in and asked why they didn't put 10W in. They said because it is warm out now it doesnt matter if it is 5 or 10 W.
I know next to nothing about oil but is this a big deal. Should I drive back up and demand they put 10W in. They have it too, they just said they put 5W in?
I do not track the car but I do drive it hard often. Is this going to screw up my engine in any way with the 5W instead of the 10W.
Next time I will just bring the Mobil 1 with me.
It will be fine.
Pleask
Dec 21, 2021 03:17 PM
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
