5AT guys!!!!Anyone try one of these transgo shift kits yet?????
Old Jun 5, 2008 | 02:29 PM
  #61
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by Jeff92se
What would a tranny shop charge for the install? Including the removal/install of the valve body?
I dont know since i did mine myself so i would just call and ask.
Old Jun 5, 2008 | 03:49 PM
  #62
coachk's Avatar
coachk
I did mine on my friends lift and it took about 3 hours from start to finish.
Old Jun 5, 2008 | 04:07 PM
  #63
Jeff92se's Avatar
Jeff92se
Man, you guys need to post a DIY! With pics!
Old Jun 5, 2008 | 04:13 PM
  #64
ZU L8R's Avatar
ZU L8R
Viper Sellout
I know PF does this modifcation in house now so if anyone is interested hit them up.
Old Jun 6, 2008 | 05:39 AM
  #65
Z ELIMINATOR's Avatar
Z ELIMINATOR
I have the stillen vb, Can i add this kit to it?
Old Jun 13, 2008 | 09:39 AM
  #66
Jeff92se's Avatar
Jeff92se
Can you detail how hard this was and comment on how much a trusted tranny shop "should" charge for the work? Thanks
Old Jun 13, 2008 | 03:14 PM
  #67
superchargedg
Damn Noobs
Its actually pretty easy as all you do is drop the trans pan and let it drain for about 20 minutes.Then just unbolt the valve body being carefull as to leave the trans selector in the same position as it came out.Take the new unit and install in reverse and be very carefull not to over tighten the v/b bolts.Fill the trans with nissan j matic fluid only and mine took 9 quarts.
The reason mine took so many is i bought mine from Zulater(Matt) who is a mod here and his came from a z-mine is a g.I had to switch over all the solenoids and electrical connectors for it to work in a g.The z has 1 connector the g has 2.
Old Jun 13, 2008 | 05:31 PM
  #68
twinship's Avatar
twinship
Originally Posted by 350Mark
Bump
Anymore reviews of this kit?
+1
I know this makes for faster shifting between gears. Are the shifts harsh?
I remember putting a shift kit in a TH400 ('69 GTO)... it made harsh and noisy. I was OK with it then, but I want something more refined in the Z.
1st hand reports anyone?
Old Jun 14, 2008 | 12:32 PM
  #69
350Mark's Avatar
350Mark
I just had it installed. Shifts are much quicker which makes the car feel quicker. Shifts aren't to harsh unless you really get on it. Wish i could test it out more but i just got a speeding ticket 3 hours after i had it installed. A "must do" upgrade if you ask me.
Old Jun 14, 2008 | 01:32 PM
  #70
OCG35's Avatar
OCG35
I thought it was a kit to rebuild the valve body... sounds like its just a new drop in VB?...
Old Jun 14, 2008 | 01:38 PM
  #71
coachk's Avatar
coachk
The Transgo is a DIY rebuild kit...Back when I did my VB they didn't have the rebuild kit. You had to take the OEM one and sent it out to have it upgraded.I think thats what superchargedg was referring to.
Old Jun 14, 2008 | 02:26 PM
  #72
twinship's Avatar
twinship
How much was the install?
When you get on it, is it a slamming feeling? (That's what I remember from the last AT I drove with a shift kit.)
lol!
Definitely on my short list.
Old Jun 14, 2008 | 02:59 PM
  #73
superchargedg
Damn Noobs
Thanks coach as that was what i was talking about.I am sorry if i mis comunicated the original op's thread.
Old Jun 14, 2008 | 03:02 PM
  #74
superchargedg
Damn Noobs
lol!
The vb does hit hard when you are full throttle esp if you are fi'ed.So i would say for you the stillen would be a better choice.It is a faster shift a bit better then stock but not harsh.
Old Jun 14, 2008 | 03:38 PM
  #75
twinship's Avatar
twinship
Thx.
I'm going to have to find some local (SoCal) peeps with the TransGo and Stillen VBs so I can get 1st hand test drives with both to see which I'm comfortable with.
Old Jun 14, 2008 | 03:48 PM
  #76
ZU L8R's Avatar
ZU L8R
Viper Sellout
Really??? I didn't know they were different from Z to G. I know there's a difference between the 03-04.5's and the 04.5's to 06's.
Old Jun 15, 2008 | 03:09 AM
  #77
superchargedg
Damn Noobs
Yep when i took mine down and we compared them side by side i was like......oh **** there not the same.I had to unbolt all the solenoids and the electronics and switch them over cause the g has 2 electrical harness connectors and the z has 1.It was no big deal once i figured it out.
Old Aug 27, 2009 | 08:04 AM
  #78
Tomeygun's Avatar
Tomeygun
Hello all
I just bought an 05 Z with this kit already installed... It shifts great going up in gears, but there is an issue with downshifting:
When going 50-60 on the highway and I ease into it, it will bypass 4th and jump to 3rd gear, BUT it will not unlock the convertor, thus it BANGS into gear. And I mean hard like I got hit from behind.
The only way to avoid this issue is to slap over to manual mode (unlocking convertor and putting in 4th) and then floor it, then slap back to auto mode.
Anyone have this same issue with this transgo kit??
HoBrahYouStink
Jun 24, 2016 10:58 PM
samansharif
Sep 25, 2015 12:31 PM
