what the F**K ... I was stranded
Old Jun 4, 2008 | 02:01 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
................. WAT?
something's not right here
Old Jun 4, 2008 | 04:51 AM
jmccartney's Avatar
jmccartney
As strange as it sounds yes it was the LED tail lights that I had put on the car. I got them off Ebay though. Another member here had the same issue. So just to make sure I took the stock tail lights off and put the LED ones back on and the car was back to the hesitation stage, put stock lights on and good to go. Strange but I know LED runs off different voltage so it must have been messing with the whole electrical system.
Old Jun 8, 2008 | 09:36 AM
jmccartney's Avatar
jmccartney
I just wanted to update everyone here. The car is back to it's normal self and runs like a bat out of h*ll! The ecu finally reprogramed itself for the mods done to the car as well. It's been a week since I swaped the tail lights and it just runs like a ****! Weird how the led tail lights were messing with the throttle response. Who knows. . . . .
Old Jun 8, 2008 | 12:18 PM
singh's Avatar
singh
_______________
wat
Old Jun 9, 2008 | 02:10 PM
greyvee05's Avatar
greyvee05
sounds like crank angle position sensor.. i got the same symptoms you got vdc, slip, check engine light on.. limped home at 5mph. i got code p0335. ecu wasnt getting a good signal from the sensor. dealer changed sensor and bolt that holds it in place.. no probs since
ps.. on 03's (which u have) there was a recall for this. hope it helps
Old Jun 9, 2008 | 02:14 PM
JSDZ33's Avatar
JSDZ33
no
Old Jun 9, 2008 | 02:15 PM
jmccartney's Avatar
jmccartney
f'ing dealer told me i had no recalls. the problem was the tail lights. dealer also wanted to charge me $250 to fix the window streaking issue!
Old Sep 15, 2008 | 12:45 PM
ADMAN's Avatar
ADMAN
Okay, so what about the people having the same issue that don't have LED tails?
Old Sep 15, 2008 | 02:41 PM
__jb's Avatar
__jb
Z + Rear Seat
Here's a couple of sections from the Service Manual that explain how to do a throttle body reset (called Idle Air Volume Learning by Nissan).
There's also a small diagram to help out with the procedure.
Old Sep 15, 2008 | 03:19 PM
infinite's Avatar
infinite
Tps?
Vigman
Nov 17, 2015 04:34 AM
nanotech
Oct 2, 2015 05:02 AM
irishfan
Oct 12, 2002 12:44 AM
