Clutch problem need help asap!!
Old Jun 15, 2008 | 10:31 PM
D_unit's Avatar
D_unit
Default Clutch problem need help asap!!
Hey guys , I'm rarely on this but I need your guys help.
My buddys has a 350z and the Oem clutch was slipping and was pretty worn out after 90k mikes on it.
Right now me and my buddy installed a nismo r-tuned clutch, nismo flywheel and nismo pressure.
The installation took long but got everything installed.
Now the problem is when we took it for a drive and around 2500rpm to 3300rpms it underloads and makes a loud hum , we though it was something hitting it like the stock Y-pipe or such but stil makes a loud "hum" noise and we don't know what else to do, we thogh it was the pilot bushing and throw out bearing but it wasn't since we took it apart again and replaced both.
If anyone know what the problem is please chime in, thanks in advance
Old Jun 16, 2008 | 01:36 AM
D_unit's Avatar
D_unit
anyone? bump bump
Old Jun 17, 2008 | 08:00 AM
mac d's Avatar
mac d
sorry i don't have any info on this but i am curious to hear what people say when they respond to you. i am about to tackle the flywheel, pressure plate etc. as well. I might hit you up for some knowledge as you have taken yours apart already.
BUMP
Old Jun 17, 2008 | 03:27 PM
D_unit's Avatar
D_unit
BUMP
for sure, we also have found that it COULD be possible that the clutch, flywheel and pressure plate is unbalanced, and already had 2-3 pro mechanics do a check on it and they assume its the clutch package being unbalanced. but now the place we ordered it from will not take it back , and is avoiding my buddy on his return on this .....
Old Jun 17, 2008 | 04:17 PM
Spike100's Avatar
Spike100
I couldn't exactly tell from your message...
Is it working correctly but just that it makes the whining noise, or is it not performing correctly as well?
--Spike
Old Jun 17, 2008 | 06:25 PM
D_unit's Avatar
D_unit
--Spike
yes it works correctly, you can shift through all the gears , but to around 2500rpms when around there it sounds like a deep deep hum sound, like almost like a intake sound when you just punch it, but it comes from under the seats and in the rear and has a loud vibration feel too
so we are still clueless
Old Jun 17, 2008 | 06:58 PM
Spike100's Avatar
Spike100
I replaced my transmission, and do get a whine sound at around 2500-3500 rpm, but never any vibration.
The vibration you describe must be "chatter" on the pressure plate. I would think this is something that requires correction.
--Spike
Old Jun 17, 2008 | 08:33 PM
D_unit's Avatar
D_unit
--Spike
correction as in replaces it? i mean we re-done it twice and had pros theres that made sure everything was on right.
any suggestions?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
