NA Cams==> woth it ???
Old Jun 24, 2008 | 12:14 PM
Hoooper's Avatar
Hoooper
lol. the info is the same...technique maybe not quite. either side, 3800 for cam install? not so much
Old Jun 25, 2008 | 12:07 AM
fairladyz220's Avatar
fairladyz220
wow....3800 for cams install ???
are you serious ?? if this is the cost of the installation then i will be off getting a turbo kit and then some rebuild stay in around 400 whp...
i guess cams ..hmm....not a good way to go ...
Old Jun 26, 2008 | 01:44 PM
bleunetizen's Avatar
bleunetizen
Default Tomei 268
Below is my dyno chart, using Tomei 268deg cams in/ex, revving upto 7200rpm.
I am happy with the result, I did the install myself so it did not cost me to put them in but it surely was a very time consuming process.
red is when the car only had AAM spacer and fujitsubo catback with a drop in filter.
blue is with stillen intake, AAM spacer, tomei 268 cams in/ex, jwt valve springs, headers, y pipie, catback, 3.9drive final gear, guess tuned ecu
green is with the same mods, the same day with dyno tuned ecu.
the car still has stock cats, im environmentally friendly!!
Old Jun 26, 2008 | 01:57 PM
Hoooper's Avatar
Hoooper
I fancy that gain quite a bit. and if dyno'd in the same gear each time, you actually lost dyno HP when you went to the 3.9FD so the gain was more than seen. nice
pslamp32
Feb 8, 2017 09:07 AM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
