installed spark plugs..
Old Jun 24, 2008 | 08:25 PM
1redZ983's Avatar
1redZ983
Default installed spark plugs..
i just installed ngk iridium IX spark plugs (Part #LFR5AIX-11) and now im getting a rough idle. i checked the hoses to make sure there were no leaks because i took off the plenum so it would make it easier to install the plugs. any other ideas why the car has a rough idle? thanks.
Old Jun 24, 2008 | 08:27 PM
SuperBlack350z's Avatar
SuperBlack350z
i'm pretty sure it has something to do with the plenum.
Old Jun 24, 2008 | 08:31 PM
1redZ983's Avatar
1redZ983
hmmm...il check that. any other suggestions?
Old Jun 24, 2008 | 08:32 PM
SuperBlack350z
make sure all of your bolts on your plenum is tight but don't over tight or you will strip it. It's VERY easy to do so on those bolts.
Old Jun 24, 2008 | 08:39 PM
fstrnldr's Avatar
fstrnldr
make sure all of the coils are plugged in securely, if you get a connector all the way on, you could have that problem as well.
Old Jun 24, 2008 | 08:40 PM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
a wrench left inside the plenum? j/k
maybe a vacuum hose you forgot to connect? <<< it happened to my car when I installed my plenum spacer...
Old Jun 24, 2008 | 08:43 PM
dmroberson's Avatar
dmroberson
Stupid question, but did you gap the plugs correctly? Or did you just install them straight out of the package.
Old Jun 24, 2008 | 08:45 PM
SuperBlack350z
those NGK comes pre-gapped.
bacalhau16's Avatar
bacalhau16
I dont think thats a stupid question at all. I think many people have put spark plugs in and never checked the gap.
I would think to check over all your hoses as well.
Old Jun 24, 2008 | 08:46 PM
dmroberson's Avatar
dmroberson
Ok, sorry. I had to ask, because I've made a similar mistake before...
Old Jun 24, 2008 | 08:48 PM
SuperBlack350z
yeah, it's a good question. I still check it before installation with those little gap coins.
Old Jun 25, 2008 | 08:25 AM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
i don't mean to hijack the thread or anything but what is the gap size for our cars, so for my future reference.
