Anyone have clutch fluid overheating issues with aftermarket headers in hot weather?
Originally Posted by yellowlady
i have been having a clutch problem that has gotten worse over time. it is pretty much the same as the OP. during hot days, hard driving, or stop and go traffic my clutch pedal does not return to the top of its arc when i remove my foot. it just stays lower and lower to the floor. after searching the forum about this i decided to do some upgrades. installed today- JWT clutch and flywheel, SS clutch line. i was so dissapointed on the ride home that the clutch pedal started doing the same thing after about 15 minutes.
my questions are: what do you think is the problem? also, as my car is still under warranty and my dealer knows of the problem, should i have them take another look. i had them check it out when the problem first developed, but they could not duplicate it. should i tell them that i just installed the new clutch and SS line? i am thinking i should as that will save them alot of time and money. please throw some advice my way.
What I have learned from my experience with this problem is that there is only a small amount of fluid in the system. Aftermarket headers produce more heat and are generally closer to the clutch fluid line. Couple that with summer time heat and fluid that degrades over time and it's no wonder there is a problem.
So far since I switched to a higher temp fluid (Motul) I haven't had the problem reoccurr.
Originally Posted by SteveZ
I replaced the slave at the same time I did the things you did, never had this problem again. It's only about a $30 part, mine failed its seals. It has a rod, piston, spring inside, it moves against the fork (at least on older cars, 07's I think changed this design) and the fork back against it. If it's seals are weak some of the fluid goes around the seals but doesn't necessarily leak.
That's where I'd go next.
thank steve,
i just took it to the dealer as it is still under warranty. my dealer is awesome and has fixed tons of stuff on my titan under warranty. they said they it is a known problem and they would take care of it. i am sure you are right.
Great thread, good info. Sounds like i solved my spongy clutch prob. I live in Sydney and as summer came on, higher temps and after parking for a while the clutch would go all spongy. I started driving got some air flow and the pedal came back to normal.
So some better fluid and SS line on the way. Nissan Dealer did nothing and Nissan Australia have yet to respond to my complaint. Ah Well its maybe the are on holiday.
Happy New Year...
Happy New Year...
