Could Braille Battery Cause This?
Old Jul 1, 2008 | 06:04 AM
RKnight's Avatar
RKnight
Default Could Braille Battery Cause This?
I was waiting in line for a car wash when my car just died. When I went to restart the engine it took a few seconds of cranking to fire up when it normally fires up almost instantly.Also the SES,VDC OFF, and SLIP lights all stay on permanantly. Took it to West Covina Nissan and the codes they got were for Cam Position Sensors and low battery voltage. They tested the Cam position sensors and they were fine so they took one look at my Braille battery and said that is the problem. I asked the mech if he had seen problems with aftermarket batteries and he said yes the ECUs in todays cars are very picky about the voltage they receive.So I go back in today to let them put a new OEM battery back in but I'm not expecting it to fix the problem. Anyone else have problems with lightweight batteries like Braille and Odessy?
Old Jul 1, 2008 | 06:10 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
its not the battery. its actually that a lot of the new nissans draw .2 to .4 amps while sitting so your battery is constantly being drawn from overnight. this will cause the battery to slowly breakdown.
give braille a call, they actually make remote battery cutoffs that will kill all the power to the car every night and will eliminate this issue for you in the future...
Old Jul 1, 2008 | 06:45 AM
Z04's Avatar
Z04
that is what happens when you put a racing battery into a daily driven car
Old Jul 1, 2008 | 07:03 AM
coachk's Avatar
coachk
Originally Posted by dave079
WOW...I was told that Blake was a straight up guy. Interesting thread
Old Jul 1, 2008 | 08:04 AM
gothchick's Avatar
gothchick
+1
I have a new Optima Yellow Top battery. After letting my car sit for nearly two weeks, the battery was so drained it almost didn't have enough amperage left to crank the starter motor.
Old Jul 1, 2008 | 08:07 AM
SpoilsofWar's Avatar
SpoilsofWar
Braille batteries suck. I have one, and it is trash. The only reason I tolerate it is because mine is a track car, and so I just leave a smart charger on it most of the time and disconnect the ground cable.
They look nice, they are light, the mount is cool; everything else about them sucks.
Old Jul 1, 2008 | 08:25 AM
RKnight's Avatar
RKnight
The battery comes in three sizes and the I have the middle size. Never had a problem with cranking power and the only time I had drainage was when I went on vacation for two weeks and forgot to disconnect it.Jeff at West Covina Nissan told me he had a Optima and was having drainage problems they couldn't track down so they put a OEM battery back in and no more problems.
Old Jul 1, 2008 | 11:28 PM
Blazemaster's Avatar
Blazemaster
so what do you guys recommend for a lightweight battery?
Old Jul 2, 2008 | 12:25 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Old Jul 2, 2008 | 04:11 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
none if you actually use the car. For a track car, a lightweight battery can be nice. For a street car, it's a waste. The weight savings are not worth the potential inconvenience.
Old Jul 2, 2008 | 04:15 AM
JAM3Z's Avatar
JAM3Z
Phenom
Even if you use the remote cutoff, you'd lose your radio presets every night and have to reset your clock .
Old Jul 2, 2008 | 09:01 AM
anotheraznguy's Avatar
anotheraznguy
i have the braille had it for a while now....
reason for going braille was cause i ended up putting the coolant reservoir in the battery location..
i daily drive the z
and have not had any issues with it not starting...
Old Jul 2, 2008 | 09:41 AM
Hoooper's Avatar
Hoooper
if you drive it daily its not really a problem cause it charges everyday. but if its like a twice a week enjoyment car, not a track car, it drains and dies
Old Jul 2, 2008 | 09:47 AM
SpoilsofWar
Originally Posted by anotheraznguy
i daily drive the z
Thats probably exactly why you dont have any issues with it...
Let the car sit for a week and let us know what happens. Which size do you have? the 6lb, 11lb, or the biggest one (forget what it weighs)?
I have the 11lb, and if the car sits with battery connected for about 3 days, it will be completely dead. Not just slow to crank - no crank at all. It has done this since new. After two times of it happening I learned my lesson and started disconnecting the ground cable after I race the car, and will put a smart charger on it from time to time.
When I had the stock battery in, the car sat for a month once, connected, while I was TDY. Came back, turned the key, it fired right up.
But for my uses, the weight reduction is worth the drawback. So I suck it up.
Old Jul 2, 2008 | 04:58 PM
anotheraznguy
i have the 15 lb one...
you do know that they sell battery tenders for them right...
my roomate has a stock m3 that is his "weekend" car
with the stock battery it tends to die from time to time...
so in the end he bought a battery tender and now it works juuust fine..
Old Jul 2, 2008 | 05:53 PM
RKnight's Avatar
RKnight
Okay so I just got home from West Covina Nissan.They let you in the shop so you can stand right there as they work on your car. Mec. replaced the Braille battery with a OEM and started the car and no more VDC OFF and SLIP lights staying on but still took a lot of cranking to get it to fire so he said yeah it must be the cam position sensor. Hooked up the code reader and it confirmed faulty CPS passenger side. Installed a new one and the car fired right up like it should and no more codes.
So in the end the Braille battery was half the problem.I had checked the voltage of the Braille and it was 12.62 volts so I don't know how it caused the VDC OFF and SLIP lights to stay on.
Old Jul 2, 2008 | 06:34 PM
Netko350Z's Avatar
Netko350Z
Braile...FAIL
Old Dec 1, 2008 | 03:09 PM
dragon11689's Avatar
dragon11689
If you let it sit that long, is it possible to recharge it with one of their chargers or does it have to be completely replaced?
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
OdesiTT
Sep 30, 2015 10:47 AM
Shane86
Sep 17, 2015 05:33 PM
