Oil pan leaking
Old Jul 4, 2008 | 06:02 PM
redline350ZZ's Avatar
redline350ZZ
Default Oil pan leaking
My oil pan is leaking oil throught the spacer and the pan itself (Turbo return line is in the spacer) I have not been able to seal it properly and have tried a couple times. Anyone have tips to help me out. Not sure if the problem is worse because I'm FI but it's pretty annoying and messy.
Old Jul 4, 2008 | 06:29 PM
gothchick's Avatar
gothchick
Take it apart.
Clean the old rtv off.
Inspect for any cracks, warp, or irregularities.
Re-apply a fresh bead of rtv.
Torque everything back down to spec.
Make sure you tighten the pan bolts in a 'star' pattern.
Old Jul 5, 2008 | 02:03 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I used 2 oil pan gaskets and no rtv and mine has been sealed for over a year.I just called NAPA and bought them i just dont like rtv.
Old Jul 5, 2008 | 06:38 PM
gothchick's Avatar
gothchick
The factory uses rtv on the pan. So that'll still need to be cleaned off and insprected.
Yeah, rtv has to be applied a certain way in a certain amount. Otherwise it can get messy. If you're not mechanically inclined or rtv challenged, then it's pretty hard to mess up a gasket. Lol~
Old Jul 6, 2008 | 12:38 PM
05Z33's Avatar
05Z33
I used RTV and it's holding strong.
Old Jul 7, 2008 | 05:35 AM
gothchick's Avatar
gothchick
Mine too... I used it with my AAM oil pan spacer...
Old Jul 7, 2008 | 05:40 AM
redline350ZZ
Well we shall see, I waited almost 24 hours before putting oil in. My pan and spacer were scratched so I don't have a completely flat surface. Not surprising considering the pans been off 4 times from a few different people. Hope the RTV fills in the gaps.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
