leaking fuel line
Old Jul 13, 2008 | 12:05 PM
stewieisslow's Avatar
stewieisslow
Default leaking fuel line
does anyone have or know where to get a diagram of the fuel lines? im leaking fuel right behind the passenger seat...i took out the glove box and see where the walbro 255 is but i see no fuel lines anywhere...do i need to take out the walbro? im stuck on this
Old Jul 15, 2008 | 10:48 AM
stewieisslow
bump
Old Jul 15, 2008 | 02:31 PM
stewieisslow
bump
Old Jul 15, 2008 | 02:53 PM
SpoilsofWar's Avatar
SpoilsofWar
After opening the glove box, remove the false bottom in the glove box, then remove the circular fuel basket assembly cover. Once you remove this you will see the fuel basket assembly (white plastic), with the fuel supply line running out of it. There will be a disconnect on top where the fuel supply line hooks to the fuel basket output.
If its not leaking at that disconnect, your fuel supply line has a hole or cut in it somewhere, or you are leaking from the tank itself.
Old Jul 16, 2008 | 08:53 AM
stewieisslow
thanks alot man ill take a look at that today
