Restore Engine Additive*****WARNING***
Old Jul 14, 2008 | 02:36 PM
krnzzang84's Avatar
krnzzang84
Default Restore Engine Additive*****WARNING***
Does anybody use Restore Engine Additive(Silver Can, come in 4,6,8 cyclinder)? I just did my oil change and added a bottle of Restore into my engine and my engine is acting really weird. Unstable idle and engine chocking as if it is gonna die. Engine light came on, i read the code it it came out to be Exhaust "Cam timing advanced"(sorry forgot the code). does anybody else have problem or i should be aware of engine additive on vq??
BTW I searched,,
Old Jul 14, 2008 | 02:41 PM
gothchick's Avatar
gothchick
Restore will blow up your engine.
Old Jul 14, 2008 | 03:35 PM
SuperBlack350z's Avatar
SuperBlack350z
i believe you are suppose to put a little less oil in there since the additive takes up volume. I would not use that stuff anyways though.
Old Jul 14, 2008 | 04:08 PM
OCG35's Avatar
OCG35
what was the reason for using the stuff anyway?
Old Jul 14, 2008 | 05:01 PM
krnzzang84's Avatar
krnzzang84
I guess RESTORE the compression!
anyways, just got done with my third oil change today,
I did oil change three times today, wtf...
Anyways VQ and restore does not go together!!
WARNING DO NOT USE RESTORE on VQ
it will create engine light and idle malfuction!!!
Old Jul 14, 2008 | 05:04 PM
krnzzang84's Avatar
krnzzang84
Does any guru or vq expert know why restore would create critical problem on our car?? My lancer seemed be fine with it.
Once restore was pured on to our engine, it definetly creats major problems.
I wonder why???
Old Jul 14, 2008 | 05:52 PM
06dieselZ's Avatar
06dieselZ
Because your car doesn't need it?
If it ain't broke don't fix it.
Old Jul 14, 2008 | 06:05 PM
R-TuneZ's Avatar
R-TuneZ
i put engine restoring additive under the same category as octane booster...
the only time i have ever used it was in really old saabs that had little to no compression and it did help... slightly... but i would NEVER use it in my own car.
Old Jul 14, 2008 | 06:12 PM
krnzzang84's Avatar
krnzzang84
Yes DO NOT PUT into Z. It will F$# it up. Not Kidding. I don't even mind not doing anything, but this triggers engine light and just kills the motor.
Old Jul 14, 2008 | 06:43 PM
track1z's Avatar
track1z
RESTORE isnt for new cars man.It probable has sludge around that sensor or the cam end after pouring it in.
Old Jul 14, 2008 | 06:47 PM
krnzzang84's Avatar
krnzzang84
but my car has 44000 miles on it
Old Jul 14, 2008 | 07:19 PM
L. Baggins's Avatar
L. Baggins
but nothing, don't do it.
Old Jul 14, 2008 | 07:24 PM
dmroberson's Avatar
dmroberson
I've got 47000 on my 06, and I don't put anything in it, unless it's necessary.
+1.
Old Jul 14, 2008 | 08:00 PM
SuperBlack350z
it probably messes up seals and stuff by cleaning the sludge off.
Old Jul 14, 2008 | 08:08 PM
krnzzang84's Avatar
krnzzang84
Yes, i am only putting Oil and Absolutely nothing!!
Mobile 1 Synth. Running like a champ
Old Jul 14, 2008 | 08:33 PM
track1z's Avatar
track1z
Default NO NO NO Listen
BTW I searched,,
This is what happened. ON the end of the cam there is cuts in the end.When you added the restore it filled in the holes and sending that sensor up ***** creek.Replace your oil again with filter.DO not put anything in your oil.Take the cam sensors out clean them and reinstall.MAKE sure the cam ends are clean aswell.
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
