Correct Torque Specs L19 and ARP
Old Jul 31, 2008 | 10:45 AM
tecni's Avatar
tecni
Default Correct Torque Specs L19 and ARP
I did a search and I came up with a whole lot of nothing so...
1) what's the correct torque spec for the ARP MAIN studs?
2) Correct Torque specs for L19 HEAD studs?
Old Jul 31, 2008 | 03:25 PM
rrmedicx's Avatar
rrmedicx
I can answer the head studs....93 ft/lbs for the L19's But it is advised to do it in stages...
Bring them up to 30 ft/lbs, then work your way up in stages...50...70...93..done. The mains I am not sure. You can ask Sharif or any of the vendors for that matter.
Old Jul 31, 2008 | 04:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
90-95 ft/lbs for the L19
60-65ft/lbs for the ARP Mains
Both are with Moly....trq will vary if you use any other lube.
When we assemble engines, we use 65ft/lb for mains, and 95 ft/lbs for L19 head studs.
Hope that helps.
Old Aug 4, 2008 | 06:39 AM
tecni's Avatar
tecni
awesome! Thanks!
What about Pauter rod bolt torque specs???
Old Oct 6, 2008 | 10:32 PM
tecni's Avatar
tecni
Torqued to sharif's specs and holding some awesome power! Thanks!!!
Old Oct 9, 2008 | 09:19 AM
maximariceboi's Avatar
maximariceboi
there was no paper work that came with the arp goods? how much power are you putting down?
Old Oct 10, 2008 | 05:17 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Not with L19s. They come individually wrapped and sleeved in a white padded box
EnjukuRacing
Sep 30, 2015 06:55 AM
