What is that "ticking" sound?..
Old Aug 9, 2008 | 08:00 PM
PRuane's Avatar
PRuane
Default What is that "ticking" sound?..
I can hear a ticking sound when I accelerate especially in first and second gear. Is this the tranny "chatter" or whatever I've read about or is this something with my suspension or axles because it occurs when my car jerks, especially in low gears because of the torque. Its not that loud and literally sounds like a tick on a clock, something I should be worried about or no?
Old Aug 9, 2008 | 09:43 PM
Mike@Blackline's Avatar
Mike@Blackline
i think its the CV joints or something that there was a TSB for. subscribed though id like to know for sure
Old Aug 9, 2008 | 09:57 PM
TheOtherRob's Avatar
TheOtherRob
My 08 makes a tick/squeek in lower gears during acceleration. Havent had time to take it in, but I assume it is the rear axle.
Old Aug 9, 2008 | 10:30 PM
PRuane's Avatar
PRuane
I have an 03 Enthusiast, I still need to take it in for inspection, I can only hear it when I have my windows down though. I still need to put pictures up but I need to get my girlfriends camera first ha. And another question does anyone slip when shifting out of first at higher RPM's close to redline, because I've pushed my car a few times now and a quick shift out of first after I chirp below my tach it say's "Slip" and I lose significant power for about a second or two then it kicks back in, I find it pretty annoying but I think I might be able to fix it with some new tires just wondering if anyone else gets the same issue
Old Aug 9, 2008 | 10:50 PM
Mike@Blackline
thats your traction control its cutting the power because the whole point of it is to maintain traction. simply hit the traction control button on the bottom left side dash. a TCS OFF or VDS OFF light should come up under the tach and then you can do this:
https://my350z.com/forum/media-share...ther-pics.html
Old Aug 10, 2008 | 04:29 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
TSB 04-065
www.notre350z.com/forum/files/<wbr>uploads/dold/1207422654_ClickClack.pdf
I just had my '05 fixed. No more clicking.
Old Aug 10, 2008 | 08:09 AM
PRuane's Avatar
PRuane
Thank you guys for the help I really appreciate it, and I really feel like an idiot with the TCS question and I have ONE MORE
There is a light coming on, on the bottom left side of my dash I believe it has to do with tire pressure but I don't have any owners manual so I cant tell it looks like this
an enclosed "oval" with two arrows pointing at a dot in the middle, that picture actually looks pretty close haha
Old Aug 10, 2008 | 08:48 AM
jwillard0201's Avatar
jwillard0201
if it looks similar to this one its your tire pressure warning light...
Old Aug 10, 2008 | 09:24 AM
Mike@Blackline
use your gauge on your dash to switch to TPS tire pressuring mode and see what numbers come up
Old Aug 10, 2008 | 09:43 AM
Dissenter's Avatar
Dissenter
The same thing happens to me, but when I turn off the VDC on my '04 Track the "Slip" light doesn't come on when I accelerate.
Old Aug 10, 2008 | 10:54 AM
Mike@Blackline
thats because you're disabling traction control when you hit the button, and the SLIP only comes on when traction control is kicking in and distributing/cutting power
Old Aug 10, 2008 | 11:37 AM
PRuane's Avatar
PRuane
Starting to get real annoyed, real fast. I just went to the mall with my Z and it was raining, on the way there I had no problems the car drove great. But on the way back I was about halfway home on the highway when I was cruising in 6th gear at about 60mph I went to pass someone and dropped it into 4th and started to accelerate it felt like the traction control kicked in because I lost power so I just stayed behind the guy in 6th until my exit. As I got off my exit I put it in 1st at a yield sign and started to accelerate, as soon as I hit 2500RPM it feels as if my car is red lining and it wont go beyond 2500RPM in ANY gear. Does anyone know what this problem is? Because it seems pretty serious to me unless for some reason 350's do this when it rains for a safety feature but I highly doubt that.
Old Aug 10, 2008 | 03:21 PM
Mike@Blackline
three things:
1. if your engine is bogging down when you downshift your timing/clutch balance is off
2. also, maybe you were hydroplaning and you actually were hitting your rev limiter but only going like 20
3. if you're starting to drive on flat dry road and you cant go past 2500 RPM (though extremely doubtful that it is actually doing that), your tranny is retarded and probably about to fail. but that doesnt make sense. if you're doing this when you burning our and peeling out around turns, the odds are you actually are bouncing the rev limiter and not realizing it. the RPMs get up there really quick....
Old Aug 10, 2008 | 04:59 PM
PRuane's Avatar
PRuane
don't know what it is, it might be something with my fuel pump, when i drove it later in the day it worked fine then randomly for about 30 seconds it did the same thing but this time it wouldn't rev past 4500 RPMS its confusing, and annoying im going to get it looked at when i get the car inspected
Old Aug 10, 2008 | 05:05 PM
Mike@Blackline
jeez that sounds really bad. try resetting your ECU. disconnect the battery and let it sit 15-20 minutes (Ive heard thats how you do it)
Old Aug 10, 2008 | 07:08 PM
PRuane's Avatar
PRuane
Alright i'll give that a try, i hope i didnt buy a lemonnnn..
Old Aug 10, 2008 | 07:13 PM
PRuane's Avatar
PRuane
My gauge isnt recording any numbers, it just stays at all 0's. I'm thinking I might have a bad sensor or is there something i need to do for the gauge to read the pressure?
Old Aug 10, 2008 | 07:29 PM
TreeFiddyZee
Do WHAAAAT!?
You have to be moving to read tire pressures. Quoting the owner's manual, "The low tire pressure warning system will activate only when the vehicle is driven at speeds above 20 MPH."
Old Aug 10, 2008 | 08:51 PM
350z2k3's Avatar
350z2k3
So...what was the ticking noise?
Old Aug 11, 2008 | 09:37 AM
PRuane's Avatar
PRuane
TSB 04-065
That explains the clicking sound, 350z2k3
