After clutch install, notchy shifting
Old Aug 12, 2008 | 05:48 PM
charged's Avatar
charged
Default After clutch install, notchy shifting
I had JWT clutch installed and noticed that I am having trouble getting clutch into 5th and is notchy in 3rd. Do you guys have a solution, is it the clutch?
Old Aug 12, 2008 | 06:33 PM
kramykram's Avatar
kramykram
Nah there is an adjustment on your pedal rod that goes into the master slave cylinder. its a 12mm nut you just loosen and adjust the rod a bit. you will see the threads on it.
Old Aug 12, 2008 | 06:42 PM
Spike100's Avatar
Spike100
Questions:
  • What year is your Z?
  • Is the problem grinding when going into the problem gear, or is it just hard to shift?
I don't think it's the new clutch.
--Spike
Old Aug 13, 2008 | 01:04 PM
charged's Avatar
charged
Originally Posted by Spike100
Questions:
--Spike
04 and can't find 5th no grinding just not going in smoothly
Old Aug 13, 2008 | 02:23 PM
Spike100's Avatar
Spike100
Hmmm... If in fact it's the clutch, I would expect problems going into any gear. But, I suppose that it could be a slight difference between the gears that shows-up on a tighter tolerance with the new clutch. Try adjusting the clutch (as kramykram suggests).
--Spike
Old Aug 13, 2008 | 04:04 PM
dcreech0's Avatar
dcreech0
I also have an 04 with a JWT clutch and flywheel. Mine has the same exact problem, its like you have to find fifth gear no. Its almost like, i dont know, it moved to the left a little. I always seem to miss the gear to the right. Anyways, I dosent slide into gear as easily as it used to.
Old Aug 13, 2008 | 04:13 PM
Biochem7's Avatar
Biochem7
Regular
There is a shifter plate that must be put in correctly or it will prevent or make going into 5th difficult.
Old Aug 17, 2008 | 06:29 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep, definitely the first thing I'd check. It's the metal guide plate that is rectagular shaped that goes under the center console
Old Aug 17, 2008 | 09:43 PM
kramykram's Avatar
kramykram
if the guide plate was out of place wouldn't more then one gear be out of whack? i have never pulled the shifter out when dropping the tranny so i really don't know what it looks like so thats why i am asking.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
