US-spec TT.. oh yea baby!
Old Sep 10, 2003 | 06:12 PM
  #161
mcduck's Avatar
mcduck
This kit is looking pretty good, but I hope that price comes down a little. I would have to pass on it if it clocks in at $8K w/o install.
As for the GReddy, I've heard anywhere from $4500 to $7000 speculated from different sources. I've also heard a kit without IC and with IC putting those prices in such a wide range.
guess it's a race to see which company will get my money! My credit card is primed and I'm just waiting on some announcements now.
Old Sep 10, 2003 | 11:10 PM
  #162
SirZaLot's Avatar
SirZaLot
So PE IS using PE1420, not PE1480. And Greddy is using bigger 18G turbo and that means Greddy is more ready to tuning for huge HP.
Old Sep 12, 2003 | 01:45 PM
  #163
spazpilot's Avatar
spazpilot
KaiKai
I don´t thimk it really matters that PE is using smaller turbos. If I am not mistaken the PE1420 is capable of 420hp per turbo and the 18g is good for 450 per side. so both of them could blow up our motor. I also believe that the reason PE used a smaller turbo was for quicker spool up and a more linear increase in power and torque.
Cheston:
Anymore news on the kit
Old Sep 12, 2003 | 10:45 PM
  #164
SirZaLot's Avatar
SirZaLot
spazpilot
Thx...
Old Sep 12, 2003 | 11:23 PM
  #165
Bone out 350Z's Avatar
Bone out 350Z
fat *** turbo.... good luck
Old Sep 15, 2003 | 09:31 AM
  #166
DaddyKool's Avatar
DaddyKool
Originally posted by Mike Wazowski
Power Enterprise
IHI Turbos <<---
low boost, big power
to be out soon
will be available from our sponsors.
Does anyone know their website?
Old Sep 15, 2003 | 09:58 AM
  #167
G3po's Avatar
G3po
Default PE TT sytem
Will PE make a kit for the G35 6MT Coupe?
Old Sep 16, 2003 | 02:30 PM
  #168
POWER350Z's Avatar
POWER350Z
Default Re: PE TT sytem
I've received numerous inquiries about this.
PE USA has been asked to look into the Nissan 350GT and purchasing a 2004 model.
I wonder why....
Old Sep 16, 2003 | 04:31 PM
  #169
FstQban's Avatar
FstQban
wow. this is the best thing I have heard about since my preorder confirmation! now only to find $8 grand to spend. How much does an install like this usually cost? Also any estimates of 1/4 mile times with the boost at the recommended level? I mean the current bars producing 394rwhp? Assuming a 14.0 sec. starting point how much time could be saved?
Old Sep 16, 2003 | 07:02 PM
  #170
Jeff@Evolution's Avatar
Jeff@Evolution
Cheston, have you thought about using the Crawford pleneum along with your turbo set up? Maybe a better gain at the high end.
Old Sep 16, 2003 | 08:36 PM
  #171
Chebosto's Avatar
Chebosto
hey jeff-
i thought about it.. but with the turbos its already forcing enough air to the end of the plenum, to where the two front banks are getting 'less' air supposedly... - my tuner suggested that it was unnecessary. and i like my stock strut bar.. i might think about the esprit spacer kit, or boring out the inside of the plenum--
i read those technical papers. nissan made 105% volumetic efficiency at 5600 rpms with the Vq... i dunno if i wanna mess with changing their plenum.. (no offense to crawford .. their plenum kicks ***) i just dont feel that its necessary right now.. i might change my mind if i decide to build it up full tilt..
Old Sep 17, 2003 | 07:15 AM
  #172
sschmuve's Avatar
sschmuve
Originally posted by Chebosto
hey jeff-
Yes..The air is being forced there, but won't there be a pressure drop due to lower CFM @ only 7psi?
Old Sep 17, 2003 | 09:05 AM
  #173
G3po's Avatar
G3po
Default Crawford
I think the point of the Crawford design isn't the actual increase in flow to the front cyclinders alone. It is the equalization of the distribution of flow in th eintake plenum. If the rear cylinders receve more Flow with ressect to the front cylinders , with FI or not, there could be a slight in-equity on the intake side.
When there is a per-cylinder an inequity, all the ECU can possibly do (even when re-mapped) is to optimze the timing and A/F to the least common denominator. THe input seonsors are "global" not localixed to any psecific set of cylinders.
But , of course the relative gain possibly had by the Crwaford mod probably paless comparison to the overall TT addtion.
But it would be an interesting apple to orange comp on the dyno.
Old Sep 18, 2003 | 08:33 AM
  #174
z33boi's Avatar
z33boi
PE or anyone who can answer this...will this kit fit or work for the 350z 5speed automatics and will there be more than jus one stage of this kit?
Old Sep 18, 2003 | 02:29 PM
  #175
POWER350Z's Avatar
POWER350Z
this kit will work for the 5spd auto as well.
Old Sep 19, 2003 | 07:52 AM
  #176
z33boi's Avatar
z33boi
nice...do you now how much boost the car will be able to handle on the stock engine with jus the turbo and what comes with it?
Old Sep 19, 2003 | 08:52 AM
  #177
zland's Avatar
zland
Sport Z Magazine
By what I have read here, I think Greddy knows how much boost it will not handle!
Old Sep 19, 2003 | 01:23 PM
  #178
Redline350zTour's Avatar
Redline350zTour
$8,000 is a little too much for a full time college student Maybe when I get my degree...
Old Sep 19, 2003 | 02:03 PM
  #179
JPizzle's Avatar
JPizzle
take a "student loan"
Old Sep 19, 2003 | 04:42 PM
  #180
spazpilot's Avatar
spazpilot
I am pretty sure Top Secret as well as Power Enterprise is aware of how much boost it can't handle. It would be called R&D. Don't think that these two companies haven't blown up any engines. They have, weather or not they tell you is a different story. Chestons car was only a prototype for the US spec version, but the turbo was in R&D for a long time in japan. that why Cheston's motor never was destroyed. Anyways I can almost Garantee you that if you were to go for reliablity, Greddy will be the way to go. But all in all, All the turbos will run at a boost that will not destroy your engine. None of these companies would be willing to lose there reputation.
