Connecting Rod
Old Aug 21, 2008 | 02:05 PM
PWSHHOCKEY44's Avatar
PWSHHOCKEY44
Default Connecting Rod
Hey guys, I broke a connecting rod the other night so I have a few questions. Can I run the Cosworth rods on stock pistons or would it make more sense to go ahead and upgrade them too? Also, does anyone know have a ballpark on what labor would be on installing rods and cams? Thanks for the help
Old Aug 21, 2008 | 02:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
That sucks
You could replace just the rods, though it's a messy, messy job and not all that easy to do with the engine in the car. If your budget and time allow, your best bet is to build the bottom end with pistons and rods
Cams is a whole other ballgame. At the point where you're at, I'd pull the motor and just built it top to bottom and be done with it (again if time/budget allow). Otherwise, you might want to look for a used motor to use for now, and build your original one outside of the car in the meantime...less downtime, and you can then go at your own pace
Old Aug 21, 2008 | 03:30 PM
PWSHHOCKEY44
Exactly what I wanted to hear. Thank you, sir!
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
