Anyone Advance timming with HyperForce System?
Old Aug 29, 2008 | 05:20 AM
NiZMo1o1's Avatar
NiZMo1o1
Default Anyone Advance timming with HyperForce System?
Just curious if anyone has advance their timming 2degrees with the HyperForce system ?
Old Aug 29, 2008 | 08:36 AM
UpRev's Avatar
UpRev
Advancing your timing a static 2 degrees isn't a useful thing. The dealership uses it for cars whose sensors are out of alignment. It's the same reason we include it in our Cipher product, if your car needs it and you have verified that it does you can advance it. If your car is pinging stock and needs to be static dropped 2 degrees you can also do that. This is not a performance modification, it is a service utility.
Trust me when I say that your ECU is more than capable of adjusting itself. If you want to adjust your timing differently because you changed grades of fuel, unplug the battery for 15 minutes and let the ECU re-learn from scratch.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
