Need immediate help - oil pressure
Old Aug 26, 2008 | 10:58 AM
buffmanjeff's Avatar
buffmanjeff
Default Need immediate help - oil pressure
I was driving this morning to work and noticed my oil pressure gauge well over 120psi. Engine temp is fine and oil level is fine...turned off the car and turned key to 'on' position and gauge is at 90psi, even though the car is off. I can't remember what it used to be so can someone please do me a favor and check what their gauge reads with the car off and the key to the 'on' position? It would help me out to determine if its the oil gauge or not. Thank you!
Old Aug 26, 2008 | 11:26 AM
coachk's Avatar
coachk
You need a new oil pressure sending unit...its right by the oil filter
Old Aug 26, 2008 | 06:55 PM
buffmanjeff
oil pressure sending unit? That what I need?
Old Aug 27, 2008 | 07:02 AM
coachk's Avatar
coachk
Thats it ....I don't know why I typed sensor.
Old Aug 27, 2008 | 03:04 PM
buffmanjeff
anyone know if this is covered under warranty?
Old Aug 27, 2008 | 05:05 PM
coachk's Avatar
coachk
Is the gauge pegging to 120 when the car is cold and you turn the key to the on position (not starting the car).Should be under warranty.Mine went out after the warranty ran out.
Old Aug 28, 2008 | 03:44 PM
buffmanjeff
yes, it jumps to 90 without the car even running and when i start the car it goes past 120. I'm going in tomorrow to see if warranty will cover this. If not i'll do it myself. Thanks.
Old Aug 28, 2008 | 04:02 PM
surfcity40's Avatar
surfcity40
there are at least 10 threads about what happens when the sending unit/sensor goes out and where it is and what it costs. search, advanced, keywords, titles only, boolean....should take you right there....
Old Aug 28, 2008 | 05:03 PM
buffmanjeff
yeah found that, thank you search police
Old Aug 28, 2008 | 05:17 PM
coachk's Avatar
coachk
If you do it yourself be careful to not over tighten it. Its a simple install if you have access to a lift.
Old Aug 28, 2008 | 05:19 PM
surfcity40's Avatar
surfcity40
yw...sry it takes so much investment....
Old Aug 28, 2008 | 05:26 PM
surfcity40's Avatar
surfcity40
yw...sry it takes so much investment to find the links....
Old Aug 29, 2008 | 10:12 AM
buffmanjeff
fixed it. close thread.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
