Need help!! Engine is on but RPM won't go up
Old Oct 7, 2008 | 07:53 PM
rcdash's Avatar
rcdash
Originally Posted by SpoilsofWar
+1 on limp mode, it should be throwing a code to tell you whats up.
Even if the SES light isnt on, you should scan to see if any codes are pending.
+1. Instead of clearing the code, read the d@mn thing so you know what to fix. Jeezuuus.
Old Oct 8, 2008 | 06:39 AM
gothchick's Avatar
gothchick
Haha. I wuz jus gonna say that.
Old Oct 9, 2008 | 06:36 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Any update ?
Old Oct 9, 2008 | 08:49 PM
lay zzz's Avatar
lay zzz
yeah it your throttle for sure..from here on out your car will do that and only every other time will it rev past that..the throttle sensor as a hickup and doesnt see the car is on do to the drive by wire..you have what i had..most likely the code will come up p2122 i think is what it was..im interested to see if its the same thing for sure.good luck
Old Oct 10, 2008 | 06:20 PM
chrisnathan's Avatar
chrisnathan
I went to Autozone, sadly they don't rent out that thing anymore. Couple days been running strong until I was about to go home today. It happened again.
So what did you do with yours? Let me know.
Old Oct 11, 2008 | 03:14 AM
ysfg35's Avatar
ysfg35
change your throttlebody
Old Oct 11, 2008 | 08:17 AM
chrisnathan
That might be one of my options, but until I found out what's going on and spend couple hundreds for something that not the real problem is. I rather wait.
Old Oct 15, 2008 | 10:32 AM
M3ANMACHINE's Avatar
M3ANMACHINE
Update??
Old Oct 19, 2008 | 08:51 PM
Nathan's Avatar
Nathan
What was the final outcome?
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
Justin100
Nov 29, 2015 03:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
