Pulleys
Old Aug 10, 2003 | 03:05 PM
Sillent Killer's Avatar
Sillent Killer
Default Pulleys
Well,
I was thinking about installing a set of pulleys in my 350Z. So I was wondering if I need to dyno tune my car after I have them installed for me to drive my car safely so it doesn't detonate. Can I still drive safely if I don't dyno tune it after I install the set of pulleys. I know that if I don't tune it I won't get as high of hp and tourque gains but I want to know if it is safe.
Old Aug 10, 2003 | 03:16 PM
12SecZ's Avatar
12SecZ
There isn't any tuning required for a pulley swap, you either detonate or you don't. A Dyno will just give you A/F and whether you have KR (probably false) if you want a good motor mod and don't plan on N20 or FI it's a good mod and there isn't any 'tuning' required or even possible.
Old Aug 10, 2003 | 03:17 PM
KONVERTER's Avatar
KONVERTER
forgive me for being dumb...
but what exactly do they do...
Old Aug 10, 2003 | 03:28 PM
Sosa's Avatar
Sosa
The crank pulley is smaller and more efficient, and the p/s pully and the alternator (or the other 2 that come in a set) are bigger and reduce the power they "steal" from the engine.
Old Aug 10, 2003 | 05:05 PM
Sillent Killer
Thanks. That helped. I will get a complete set. Do you know where I can get a set taht is cheap.
Old Aug 10, 2003 | 05:29 PM
Sillent Killer
I want to get the Unorthodox Racing Ultra SS set. I found it for $340 on www.unorthodoxracing.com. It is $399.99 and is 15% off. Is there any other store that sells it cheaper.
Old Aug 10, 2003 | 06:48 PM
Blownaway's Avatar
Blownaway
So are you saying that you cant run pulleys if you are planning on spraying? If that is so, can you please tell me why...Gracias...
Old Aug 10, 2003 | 07:15 PM
spazpilot's Avatar
spazpilot
you can't run pulleys if you are planning on doing a supercharger. you will underdrive it and put out less boost.
Old Aug 10, 2003 | 07:45 PM
sdpearso's Avatar
sdpearso
Just to clarify...
The UnorthodoxRacing kit consists of a lightweight underdrive crank pulley and 2 lightweight accessory pulleys. The accesory pulleys are not sized differently for underdriving, they are only lighter weight than stock.
Old Aug 10, 2003 | 08:19 PM
DeeZee's Avatar
DeeZee
yea, why cant you use pulleys and spray???? max, wasnt it you that was doing that?
Old Aug 10, 2003 | 10:59 PM
Lokeey's Avatar
Lokeey
On a stock setup....how much horse does the pully set give you?????
Old Aug 11, 2003 | 07:04 AM
spazpilot's Avatar
spazpilot
nissan magazine did a test on them 2-3 throughout the band and a peak of 5 at the wheels
http://www.nissanperformancemag.com/august03/350pulley/
there is the link if you want to take a look. pretty good numbers if you ask me. I have it and like them
Old Aug 11, 2003 | 07:42 AM
Sillent Killer
Can I still use this pulley set with a turbocharger. I want to get the GReddy kit but Also want to get the pulleys. I am also pretty sure that it gives 8-15 hp gain and 6-10 tourque gain on a N/A engine. If it is turbocharged you can gain 10-18 hp and 10-20 tourque.
Old Aug 11, 2003 | 08:14 AM
spazpilot's Avatar
spazpilot
Sillent Killer:
yes you can use it on a turbocharged engine. as for hp if you click on the link above you can read about how much hp it makes on the 350z. its only 5 rwhp peak and 3lbs torque. you will get more out of a turbocharged engine but no one knows yet how much more. every car is different. they say on the 300zx it was 22rwhp (doubt it). on my old eclipse it was a peak of 8rwhp.
Old Aug 11, 2003 | 08:22 AM
Sillent Killer
Thanks. Where can I get a good deal on a set or pulleys.
Old Aug 11, 2003 | 10:28 AM
spazpilot's Avatar
spazpilot
bought my here http://www.2kracing.com/350z-engine.shtml
same price as everywere else just free shipping
Old Aug 11, 2003 | 11:22 AM
peptidbond's Avatar
peptidbond
My experience tells me to avoid 2Kracing, but that is my experience. I would try www.350zforums.org (note the .ORG). They have the cheapest price I have seen, they carry all the colors, and they typically have them in stock.
As a side note, I put these on my car the other day and it is easy. The HP gain is small, but worth it. The real benefit is that the engine revs MUCH faster and downshifting without double-clutching is more smoothe. I seriously rank this as one of my best mods.
Old Aug 11, 2003 | 12:21 PM
Sillent Killer
Everything at that store is cheap. Thanks.
Old Aug 11, 2003 | 12:39 PM
wren57's Avatar
wren57
Yeah, definately check out 350zforums.org.
http://www.350zforums.org/store/?pag...f8d7446e0084d6
Tell him Wren sent ya...
Old Aug 18, 2003 | 05:55 PM
Sillent Killer
k
