New oil cooler
Old Oct 15, 2008 | 01:35 PM
robbinsj's Avatar
robbinsj
Default New oil cooler
Just got a new oil cooler and was wondering the best way to add extra oil to compinsate for the cooler system?
Old Oct 15, 2008 | 01:43 PM
Equinox's Avatar
Equinox
Add oil, check oil dipstick level, turn on motor for a bit, turn off motor, check oil dipstick level, repeat as necessary
Old Oct 16, 2008 | 04:40 AM
robbinsj's Avatar
robbinsj
Thanks, anyone added an oil cooler system? How much more oil did you need?
Old Oct 16, 2008 | 05:46 AM
QuadCam's Avatar
QuadCam
that won't work if the oil cooler is higher than the pan.........as the oil all drains back into the pan.......and throws off your dipstick readings.
the best technique is to fill the oil cooler and lines with oil prior to installation and measure the aded volume......that way you know, for sure, how much capacity you have added!
Old Oct 16, 2008 | 06:05 AM
robbinsj's Avatar
robbinsj
Good idea, tks!
Old Oct 16, 2008 | 06:25 AM
gothchick's Avatar
gothchick
My oil cooler has the lines going in and coming out of the top - So no drain back from the cooler.
My oil cooler + lines + sandwich plate took about 3/4qt extra to fill.
Old Oct 16, 2008 | 02:47 PM
Equinox's Avatar
Equinox
Thanks! I had not thought of that. Learn something new everyday
Old Oct 20, 2008 | 10:37 AM
VO...'s Avatar
VO...
Administrator
I wanna say my ARC cooler added an extra space for 1/2 quart. I'm not really sure to be honest. I haven't changed my oil in over a year now.
Having a DD FTW...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
